Using a mapped boundary condition with a transform |
January 21, 2020, 14:10 |
Michael
Rep Power: 9 |
I am creating a model of a circular oil cooler. The cooler is a single pipe that circumnavigates the central block 6 times. I was trying to limit my model to 1/16th of the full 360 degrees. The resulting model is a section of a cylindrical ring with 6 distinct pipes running circumferentially through it. Because the water in each pipe is distinct, I have to have six different regions for the water. As the water in the pipe ends up flowing through all six pipes in the model, I was trying to link the input temperature and velocity of each pipe to the output of the previous pipe. I also want to perform a transform on the temperature to account for the heat loss that occurs in the unmodeled portion of the cooler. I have determined that I can't use a cyclic boundary condition as cyclic doesn't work between different regions. I was wondering if there was a mapped boundary condition which also includes a transform. Thanks! |
boundary condition., mapped, openfoam |
The difference of cyclic boundry condition and mapped boundary condition | caitao | OpenFOAM Running, Solving & CFD | 1 | December 4, 2019 07:29 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
several fields modified by single boundary condition | schröder | OpenFOAM Programming & Development | 3 | April 21, 2015 05:09 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
