array of volScalarfield
Old   May 31, 2018, 21:27
Post array of volScalarfield
Anshul
sonGoku is on a distinguished road
i tried to declare an array of type volScalarfield as-
volScalarField Xsi
IOobject
"Xsi",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("Xsi", dimless, 0)
volScalarField
IOobject
"Xsi[" + std::to_string(4) + "]",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
mesh,
Xsi[4]
which compiled well
but when I added eqn in my main code as-
fo<< "\nCalculating Xsi\n" << endl;
for(int i =0 ; i<5 ; i++)
{ volScalarField& Xsii = Xsi[i];
while (pimple.correctNonOrthogonal())
fvScalarMatrix XsiiEqn
fvm::ddt(Xsii)-pow(1-Xsii,n)*A_1*exp(-Ea_1/(R*T))
== fvOptions(Xsii)
fvOptions.constrain(XsiiEqn);
XsiiEqn.solve();
fvOptions.correct(Xsii);
it displayed compilation error as follows-
error: invalid initialization of reference of type ‘Foam::volScalarField& {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&}’ from expression of type ‘double’
/home/anshul/OpenFOAM/OpenFOAM-dev/wmake/rules/General/transform:25: recipe for target '/home/anshul/OpenFOAM/OpenFOAM-dev/platforms/linux64Gcc62DPInt32Opt/applications/solvers/basic/ablationFoam/ablationFoam.o' failed
I don't know if there is problem in my declaration of array or initialization of field Xsii
Pls anyone Guide me through this.
Any sort of help is highly appreciated
Thank You
sonGoku is offline   Reply With Quote
Old   April 30, 2020, 06:06
geth03 is on a distinguished road
if you read the error:
you see that you create a reference of type volScalarField and try to reference an object of type double, which is illegal. your reference type must be the same as your referenced type.
geth03 is offline   Reply With Quote
array, volscalarfield, volscalarfield list
Adding new member function to GidaspowErgunWenYu.C of dragModel kiang OpenFOAM Programming & Development 0 June 21, 2017 05:23
Newly defined volScalarField "indexT" has different array ranges in paraview nero235 OpenFOAM Programming & Development 1 September 30, 2016 11:57
execFlowFunctionObjects - unknown field problem Toorop OpenFOAM Post-Processing 16 March 14, 2016 03:25
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 06:16
