Coefficients of RAS model for particles in TwoPhaseEulerFoam |
May 4, 2020, 08:30 |
Rep Power: 6 |
I have started simulation of a fluidized bed in TwophaseEulerFoam. It should be mentioned that I am quite new regarding to my work with openFoam. I got the problems when started to consider turbulence Properties for particles. Could someone help me with advising or recommendation where I can find the detailed instruction or guidance how correctly to choose all coefficients for my case and what is the meaning of these coefficients.
I have attached the tutorial file "turbulence Properties.particles" with the values provided. I can not find this information in UserGuide. Any help would be highly appreciated. |
May 29, 2020, 03:55 |
Rep Power: 8 |
normally, coefficients for turbulence models are fitted to experimental data.
for more information you should check out the original paper/source. |
May 29, 2020, 15:18 |
Rep Power: 6 |
Thank you.
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
VOF model + mixture model + RAS or LES model | ebtedaei | OpenFOAM Running, Solving & CFD | 23 | May 12, 2018 03:36 |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
change RAS model | Jackie Chen | OpenFOAM | 2 | February 26, 2014 05:14 |
