How to implement time-varying boundary conditions in an enclosed cylinder
Old   May 14, 2020, 06:29
Question How to implement time-varying boundary conditions in an enclosed cylinder
Alejandro
Alejandro-FA is on a distinguished road
Hi, I've been working with OpenFOAM for the past few weeks. The goal of my project is to simulate a viscoelastic fluid in a closed cylinder, in which the top and bottom face are moving up and down with a sinusoidal and coherent motion (when the bottom face moves up, the top face goes up too, and vice versa). You could think that the bottom face is moved by a motor, and that the top face is connected to the bottom one.
Said so, I'm having trouble establishing the appropriate pressure boundary conditions. So far, my blockMeshDict looks like this:
|  \\    /   O peration     | Version:  7.0                                   |
|   \\  /    A nd           | Website:  https://openfoam.org                  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
radius      0.025;
radiusNeg  -0.025;
box         0.010;
boxNeg     -0.010;
zMax        0.50;
zMin       -0.50;
nR          7;
nZ          20;
verbose no;
geometry
    cylinder
	// Axis point at the start i Axis point at the end i Cylinder radius
        type      searchableCylinder;
        point1    (0 0 -1);
        point2    (0 0  1);
        radius    $radius;
// Scaling factor for the vertex coordinates
scale 1;
// List of vertex coordinates
vertices
    // Inner
    ($boxNeg $boxNeg $zMin)
    ($box    $boxNeg $zMin)
    ($boxNeg $box    $zMin)
    ($box    $box    $zMin)
    // Outer block points
    project ($radiusNeg $radiusNeg $zMin) (cylinder)
    project ($radius    $radiusNeg $zMin) (cylinder)
    project ($radiusNeg $radius    $zMin) (cylinder)
    project ($radius    $radius    $zMin) (cylinder)
    // Inner
    ($boxNeg $boxNeg $zMax)
    ($box    $boxNeg $zMax)
    ($boxNeg $box    $zMax)
    ($box    $box    $zMax)
    project ($radiusNeg $radiusNeg $zMax) (cylinder)
    project ($radius    $radiusNeg $zMax) (cylinder)
    project ($radiusNeg $radius    $zMax) (cylinder)
    project ($radius    $radius    $zMax) (cylinder)
// Ordered list of vertex labels and mesh size
// ($nR $nR $nZ) numbers of cells in each direction
// simpleGrading cell expansion ratios
//The shape is always hex since the blocks are always hexahedra.
blocks
    // Arc 3D inferior
    hex ( 4  5  1  0 12 13  9  8) ($nR $nR $nZ) simpleGrading (1 1 1)
    // Arc 3D esquerra
    hex ( 4  0  2  6 12  8 10 14) ($nR $nR $nZ) simpleGrading (1 1 1)
    // Arc 3D dret
    hex ( 1  5  7  3  9 13 15 11) ($nR $nR $nZ) simpleGrading (1 1 1)
    // Arc 3D superior
    hex ( 2  3  7  6 10 11 15 14) ($nR $nR $nZ) simpleGrading (1 1 1)
    // Rectangle interior
    hex ( 0  1  3  2  8  9 11 10) ($nR $nR $nZ) simpleGrading (1 1 1)
edges
    project  4  5 (cylinder)
    project  7  5 (cylinder)
    project  6  7 (cylinder)
    project  4  6 (cylinder)
    project 12 13 (cylinder)
    project 13 15 (cylinder)
    project 12 14 (cylinder)
    project 14 15 (cylinder)
boundary
  inlet
      type patch;
      faces
            (0 1 5 4)
            (1 3 7 5)
            (2 6 7 3)
            (0 4 6 2)
            (0 2 3 1)
    outlet
        type patch;
        faces
            (8 12 13 9)
            (9 13 15 11)
            (10 11 15 14)
            (8 10 14 12)
            (8 9 11 10)
    walls
        type wall;
        faces
            (4 5 13 12)
            (4 12 14 6)
            (5 7 15 13)
            (6 14 15 7)
mergePatchPairs
My 0/U file looks like this:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type uniformFixedValue;
        uniformValue sine;
        uniformValueCoeffs
            amplitude 0.00742;
	    scale     (0 0 1);
            frequency 5.9;
            start     0;
            level     (0 0 0);
    outlet
        uniformValue sine;
        uniformValueCoeffs
            amplitude 0.00742;
	    scale     (0 0 1);
            frequency 5.9;
            start     0;
            level     (0 0 0);
    walls
	type noSlip;
And my 0/p file looks like this:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
	type            fixedFluxExtrapolatedPressure;
    walls
	type            zeroGradient;
    outlet
I have tried using fixedFluxPressure, fixedFluxExtrapolatedPressure, zeroGradient for one face and fixedValue for the other one, and combinations of all of them. But the problem is always the same one. I can't understand why, but when I view the pressure with paraView, one of the faces has an oscillating pressure (expected), but the other one has a fixed pressure value (with value 0).
Is there something that I'm doing wrong? Should not the pressure have an oscillating behavior on both faces? If anyone has any idea of how I could implement the aforementioned system and what I am doing wrong, I would very much appreciate it.
(By the way, I am using rheoTool in order to implement a viscoelastic Giesekus fluid: https://github.com/fppimenta/rheoTool).
Alejandro-FA is offline   Reply With Quote
boundary conditions, closed volume, pressure bc, rheotool, time-varying bc
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
