September 22, 2020, 09:48 |
primitiveEntry Error
Doğukan Karbal
Hello foamers, i'm trying to solve a T junction problem (tutorial link), when i'm running paraView code tells me:
"ill defined primitiveEntry starting at keyword 'value' on line 47 and ending at line 55" file: /home/dodo1337_emektarv2/OpenFOAM/dodo1337_emektarv2-8/run/T_junction/0/U at line 55. Here's my U code: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet_one { type fixedValue; value uniform (0.1 0 0) } inlet_two { type fixedValue; value uniform (-0.2 0 0) } outlet { type zeroGradient; } walls { type fixedValue; value uniform (0 0 0) } } // ************************************************************************* // |
September 22, 2020, 11:37 |
Adhiraj
You missed some semicolons.
The entries should be like this: Code:
inlet_one { type fixedValue; value uniform (0.1 0 0); } |
September 22, 2020, 11:41 |
Doğukan Karbal
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
