error while performing setField in wigley hull case
Like Tree1Likes
  • 1 Post By petros
Old   September 24, 2020, 12:10
Default error while performing setField in wigley hull case
Deutschland
vava10 is on a distinguished road
Hey
I am new to OpenFoam and I am using OpenFoam v-2006
I am working with wigley hull case from https://github.com/OpenFOAM/OpenFOAM...oam/wigleyHull
I followed the following steps
1. blockMesh
2. snappyHexMesh -overwrite
3. transformPoints -scale '(2 1 1)'
4. cp 0/alpha1.org 0/alpha1
5. setFields
when I run setFields I get the following error:
| \\ / O peration | Version: v2006 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _b45f8f6f58-20200629 OPENFOAM=2006
Arch : "LSB;label=32;scalar=64"
Exec : setFields
Date : Sep 24 2020
Time : 17:54:26
Host : LAPTOP-A0NOGRUJ
PID : 3337
I/O : uncollated
Case : /home/sam/OpenFOAM/OpenFOAM-v2006/tutorials/wigleyHull
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM Warning :
From static Foam::IOstreamOption::compressionType Foam::IOstreamOption::compressionEnum(const Foam::word&, Foam::IOstreamOption::compressionType)
in file db/IOstreams/IOstreams/IOstreamOption.C at line 115
Unknown compression specifier 'compressed', using compression off
Create mesh for time = 0
Reading setFieldsDict
Setting field default values
Setting internal values of volScalarField alpha1
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for hull
file: /home/sam/OpenFOAM/OpenFOAM-v2006/tutorials/wigleyHull/0/alpha1.boundaryField at line 26 to 49.
From void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file /home/pawan/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 172.
FOAM exiting
I don't know why I am getting this error is coming
I will greatly appreciate if anyone could help me with this.
If you need any further information, please ask
Regards
vava10
vava10 is offline   Reply With Quote
Old   September 24, 2020, 16:04
Deutschland
I solved the issue.
I don't know how to remove the post.
If anyone could tell me how to I will remove it
Old   September 25, 2020, 06:36
Petros Ampatzidis
petros is on a distinguished road
You do not need to remove the post. If you have the solution you may post it under your initial post so that if someone from the community faces the same issue with you in the future he/she can find the answer by a quick search without having to open a new thread.
Best,
Petros
vava10 likes this.
petros is offline   Reply With Quote
Old   September 25, 2020, 09:17
Deutschland
hey,
the issue was when I did blockMesh the boundary file created had 'hull' as the surface name, while all other files in the 0 folder had 'hull_wall' as its name.
You can resolve the issue by changing all the 'hull_wall' to 'hull'
kind regards
vava10
Free Surface Ship Flow timfranke OpenFOAM Running, Solving & CFD 322 March 3, 2021 09:04
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Wigley hull test case giovanni ieria Main CFD Forum 0 November 22, 1999 11:30
