hollow volume in snappyhexmesh
Old   November 4, 2020, 10:51
Default hollow volume in snappyhexmesh
Bineet Mehra
bineet_aero is on a distinguished road
I am trying to use snappyhexmesh to model a conjugate heat transfer problem. There are many solids to be cooled by a fluid. I am using .stl for different components to be meshed for a particular solid. However, not all of them are meshed properly. For example for a particular setting of blockMesh solid 1 is meshed while solid 2 is not meshed and its hollow (no volume mesh for solid 2 as seen in Paraview) and for other setting of blockMesh Solid 1 is not meshed ie hollow in paraview while solid 2 is meshed etc etc. Do you know why it is so and why the result depends so much on the background mesh given by blockMesh.
Thanks in advance for help
bineet_aero is offline   Reply With Quote
blockmesh, openfoam, snappyhexmesh
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 18:28
multiphaseEulerFoam high Courant number Frenk_T OpenFOAM 5 November 24, 2016 03:23
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
