Problems with preserving baffles with scotch parallel decomposition
Like Tree1Likes
  • 1 Post By simply-alex
Old   November 22, 2019, 06:24
Question Problems with preserving baffles with scotch parallel decomposition
Anna Feichtner
AnnaF is on a distinguished road
Hi all
I am trying to decompose my case with the scotch (and simple) method with baffle/patch preservation, but my baffle (set up as cyclic) gets split between two processors.
It is a 2D mesh with a vertical surface which is defined as a baffle/faceZone. The baffle gets split between two processors when I decompose the domain into 14 subdomains, which leads to problems later on. I don't get any error messages, but I get a message that the baffle is specified:
  Selecting decompositionMethod scotch
  Selecting decompositionConstraint preserveBaffles
  preserveBaffles : setting constraints to preserve baffles
  Selecting decompositionConstraint preservePatches
  preservePatches : adding constraints to keep owner of faces in patches 1(plateBaffle) on same processor. This only makes sense for cyclics.
  Selecting decompositionConstraint preserveFaceZones
  preserveFaceZones : adding constraints to keep owner and neighbour of faces in zones 1(plateBaffle) on same processor
Please find pictures attached that show the baffle in red and the mesh parts of the two processors containing the baffle in blue and gray.
Things do work (baffles/patches exist and give correct results) when I decompose into e.g. 4 subdomains, but this could just be lucky as it doesn't have to split the baffles.
One question in general: Shouldn't baffles (or patches) be preserved with the scotch method automatically?
As it didn't preserve my baffles automatically, I added constraints for preservation to my decomposeParDict as follows:
numberOfSubdomains 14;
method          scotch;
constraints
    // Keep owner and neighbour of baffles on same processor
    // (ie, keep it detectable as a baffle).
    // Baffles are two boundary face sharing the same points
    preserveBaffles //baffles
        type    preserveBaffles;
        enabled true;
    preservePatches //patches
        type    preservePatches;
        patches (plateBaffle); //(plateFront plateBack plateBaffle); //NO COMMAS!
        //patches   (plateFrontPatch_half0 plateBackPatch_half0 plateBafflePatch_half0);
        enabled true;
    preserveFaceZones //faces
        type    preserveFaceZones;
        zones   (plateBaffle); //(plateFront plateBack plateBaffle);
        //zones   (plateFrontPatch_half0 plateBackPatch_half0 plateBafflePatch_half0);
        enabled true;
I have tried a few options as you can see, but all give me the same result: a decomposition across the baffle, no error messages. Of course, I could find a different number of subdomains which works out as a workaround, but I would like to have 14 for comparative reasons and it might be a bug (?)....
Please find my case attached.
Maybe someone has an idea?
Best wishes
Anna
Last edited by AnnaF; December 6, 2019 at 06:03. Reason: more trials; syntax correction; clarification
AnnaF is offline   Reply With Quote
Old   December 5, 2019, 09:21
Anna Feichtner
I still do have this problem... does anyone have an idea?
Old   June 19, 2020, 13:14
Syavash Asgari
syavash is on a distinguished road
Hi Anna,
I am working with an older version of OpenFOAM (2.3.1), but I've got the same problem. I need to preserve a certain planar inlet patch on one process.
I have used similar options in decomposePar, but they apparently not working.
Did you find a solution for this issue?
Kind regards,
syavash
syavash is offline   Reply With Quote
Old   June 19, 2020, 14:47
Anna Feichtner
Dear syavash
Unfortunately, I couldn't solve the problem with the scotch decomposition method. Instead I used manual decomposition to avoid this.
Good luck
Anna
Old   June 19, 2020, 16:32
Syavash Asgari
Dear syavash
Good luck
Anna
Anna,
Happy to hear that it worked for you.
How many processes you decomposed into?
I have seen how manual method works, but I wonder if there is a straightforward way to use it for large number of processes (over 100)?
Kind regards
Syavash
Old   June 21, 2020, 06:21
Anna Feichtner
Hi again
I have not looked into it for a larger number of processes. I only decomposed into 14 subdomains which was obviously not much effort to do it manually. I will have another look at my case and if I find out more I would give you an update.
Best wishes
Anna
Old   April 6, 2021, 03:04
Alexandra H
simply-alex is on a distinguished road
Are you still facing the same problem?
Depending on which type of internal boundary you introduce, OpenFOAM wants different constraints (as you know).
For baffles
    baffles
        enabled true;
For cyclics
    patches
        type    preservePatches; //set (".*") for all patches, & DONT USE COMMAS!
        patches (cyclicPatchA0 cyclicPatchA1 cyclicPatchB0 cyclicPatchB1);
        enabled false;
for AMIcyclics
    processors
        type    singleProcessorFaceSets;
        sets
        (       (cyclicAMI_A    -1) //these names are specefied in topoSetDict
                (cyclicAMI_B    -1) //these names are specefied in topoSetDict
        enabled true;
could it be that you are using AMI cyclics in your setup?
fly_light likes this.
simply-alex is offline   Reply With Quote
Parallel decomposition for large cases me3840 OpenFOAM Pre-Processing 0 March 28, 2019 16:10
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
OpenFOAM Scotch Decomposition: Version and Reference dancfd OpenFOAM Pre-Processing 4 April 16, 2014 21:40
Problems with MFIX code and Parallel Processing. Fernando Pio Main CFD Forum 4 August 29, 2006 14:33
CFX - Parallel Problems CFX User CFX 0 November 1, 2004 18:12
