Trouble with kappa lookup
Old   July 8, 2015, 16:28
Default Trouble with kappa lookup
anon
cal25 is on a distinguished road
I am attempting to use the turbulentTemperatureRadMixed boundary condition and would like to set kappa to a constant. I have set kappa to "lookup", kappaName to "kappa", and tried placing a volScalarField file named "kappa" in both my constants folder and my 0 folder. Regardless of where I put this file I will always get the following error:
Did not find field kappa on mesh tunnel patch tunnel_to_HX
tunnel is one of my domains and HX is my other.
Where am I supposed to define kappa when using the lookup option?
cal25 is offline   Reply With Quote
Old   June 14, 2020, 19:50
Mitsuru Nishikawa
mit326 is on a distinguished road
I also confronted the same trouble.
Does anyone know how to resolve this problem?
mit326 is offline   Reply With Quote
Old   February 18, 2021, 07:24
juan
juanf is on a distinguished road
Did you manage to resolve this problem?
Thanks.
juanf is offline   Reply With Quote
Old   March 12, 2021, 14:46
Fabian Friberg
lumpor is on a distinguished road
I think you would need to change the solver's code and create an IOobject in the object registry (similar to what's done in the creatFields.h file of most solvers).
lumpor is offline   Reply With Quote
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 20:47
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) toolpost OpenFOAM Installation 15 September 21, 2012 09:38
Convergence on anisotropic tetahedral meshes pbo OpenFOAM Running, Solving & CFD 12 December 14, 2010 11:59
Error with 'vanAlbada' scheme Julian K. OpenFOAM Running, Solving & CFD 0 June 18, 2009 09:31
Buoyancydriven cavity flow anita OpenFOAM Running, Solving & CFD 3 March 26, 2008 10:24
