Can we initialize weakly compressible solver with potentialFoam ? |
April 13, 2021, 09:39 |
Kermit
Rep Power: 5 |
Hello everyone !!
I'm currently trying to simulate the flow around a cylinder (Re=3900) in order to extract the acoustic fields. To do so I'm using the rhoPimpleAdiabaticFoam (weakly compressible solver) solver which is particularly efficient for low Mach number flows. I'd like to know if we can use potentialFoam to initialize U and P ? Note that the 0/ folder contains all those paramaters files: alphaT, k, epsilon, nut, p, T, U. Thanks! Tyskies |
April 14, 2021, 12:29 |
thanat
Rep Power: 5 |
Hi, How can you get the result of acoustic? Did you get them ex SPL
April 14, 2021, 12:46 |
Herpes Free Engineer
Rep Power: 12 |
potentialFoam is only for incompressible flows, as far as I know. for compressible flows, you will need to implement your code, I'm afraid OR you can only use velocity field produced by potentialFoam.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
DES, DDES, IDDES for compressible solver rhoCentralFoam | eddykendo | OpenFOAM Running, Solving & CFD | 3 | February 22, 2022 04:04 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
Compressible Solver Implementation in FSI Library (Foam-extend 3.2) | KarthickRajkumar | OpenFOAM Programming & Development | 1 | January 4, 2017 06:45 |
Difference between Compressible CFD solver and Incompressible CFD solver | arijith | Main CFD Forum | 6 | September 23, 2012 19:23 |
Liquid instead of gas in a compressible solver !? | iggor | OpenFOAM | 15 | October 14, 2009 11:58 |
