May 24, 2021, 17:09 |
problem of using setExprFields
Hi guys,
Due to the fact that swak4foam could not be installed on the cluster (most of the libraries were compiled but funkySetFields cannot be found), as shown in following: Code:
/cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++:5: /cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++OptBDW: No such file or directory make: *** No rule to make target `/cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++OptBDW'. Stop. /cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++:5: /cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++OptBDW: No such file or directory /cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++:5: /cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++OptBDW: No such file or directory /cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++:5: /cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++OptBDW: No such file or directory make: *** No rule to make target `/cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++OptBDW'. Stop. wmake error: file 'Make/linux64IccDPInt32OptBDW/sourceFiles' could not be created in /galileo/home/userexternal/qyang001/OpenFOAM/qyang001-v1912/swak4Foam/Utilities/makeAxialMesh Code:
libEulerianInterfacialSedModels.so libEulerianPpSedModels.so libgranularRheologySedModel.so libgroovyBC.so libgroovyStandardBCs.so libkineticTheorySedModel.so libmyturbulenceModels.so libsimpleCloudFunctionObjects.so libsimpleFunctionObjects.so libsimpleLagrangianFunctionObjects.so libsimpleRegionSolvers.so libsimpleSearchableSurfaces.so libsimpleSwakFunctionObjects.so libswak4FoamParsers.so libswakChemistryModelFunctionPlugin.so libswakCloudFunctionObjects.so libswakCoalCloudAdaptor.so libswakDynamicMeshFunctionPlugin.so libswakDynamicMesh.so libswakFacSchemesFunctionPlugin.so libswakFiniteArea.so libswakFunctionObjects.so libswakFvcSchemesFunctionPlugin.so libswakFvOptions.so libswakGeneralLanguageIntegration.so libswakLagrangianCloudSourcesFunctionPlugin.so libswakLagrangianParser.so libswakLocalCalculationsFunctionPlugin.so libswakLuaIntegration.so libswakMeshQualityFunctionPlugin.so libswakMeshWaveFunctionPlugin.so libswakMRFFunctionPlugin.so libswakPython3Integration.so libswakPythonIntegration.so libswakQuantileFunctionPlugin.so libswakRadiationModelFunctionPlugin.so libswakRandomFunctionPlugin.so libswakScriptableLagrangian.so libswakShiftFieldFunctionPlugin.so libswakSourceFields.so libswakStateMachine.so libswakSurfacesAndSetsFunctionPlugin.so libswakThermoTurbFunctionPlugin.so libswakTopoSources.so libswakTransportTurbFunctionPlugin.so libswakVelocityFunctionPlugin.so libtwoPhaseModel.so libtwoPhaseTurbulenceModels.so The following scripts are only available for funkySetFieldsDict so how to transfer the right style into setExprFields. Thanks a lot. Code:
expressions ( sedimentvelocity { field Ua; //field to initialise fields ( z Ua ); lookuptables ( { name inletprofilesedvel; outOfBounds clamp; file "$FOAM_CASE/1d_profil/Ua0.xy"; } { name inletprofilesedvelv; outOfBounds clamp; file "$FOAM_CASE/1d_profil/Ua2.xy"; } { name inletprofilesedvelw; outOfBounds clamp; file "$FOAM_CASE/1d_profil/Ua1.xy"; } ); value uniform (1 0 0); expression "vector(inletprofilesedvel(pos().z),inletprofilesedvelv(pos().z),inletprofilesedvelw(pos().z))"; keepPatches 1; } fluidvelocity { field Ub; //field to initialise fields ( z Ub ); lookuptables ( { name inletprofilefvel; outOfBounds clamp; file "$FOAM_CASE/1d_profil/Ub0.xy"; } { name inletprofilefvelv; outOfBounds clamp; file "$FOAM_CASE/1d_profil/Ub2.xy"; } { name inletprofilefvelw; outOfBounds clamp; file "$FOAM_CASE/1d_profil/Ub1.xy"; } ); value uniform (1 0 0); expression "vector(inletprofilefvel(pos().z),inletprofilefvelv(pos().z),inletprofilefvelw(pos().z))"; keepPatches 1; } alpha { field alpha_a; //field to initialise fields ( z alpha ); lookuptables ( { name inletprofilealpha; outOfBounds clamp; file "$FOAM_CASE/1d_profil/alpha_a.xy"; } ); expression "inletprofilealpha(pos().z)"; keepPatches 1; } pb { field p_rbgh; //field to initialise fields ( z p_rbgh ); lookuptables ( { name inletprofilepb; outOfBounds clamp; file "$FOAM_CASE/1d_profil/p_rbgh.xy"; } ); expression "inletprofilepb(pos().z)-3.998*(pos().x-0.8)"; keepPatches 1; } k { field k; //field to initialise fields ( z k ); lookuptables ( { name inletprofilek; outOfBounds clamp; file "$FOAM_CASE/1d_profil/k.xy"; } ); expression "inletprofilek(pos().z)"; keepPatches 1; } omega { field omega; //field to initialise fields ( z omega ); lookuptables ( { name inletprofileomega; outOfBounds clamp; file "$FOAM_CASE/1d_profil/omega.xy"; } ); expression "inletprofileomega(pos().z)"; keepPatches 1; } ); |
May 25, 2021, 15:15 |
Herpes Free Engineer
Rep Power: 12 |
A good-quality documentation about "expressions" can be found here. Hope this helps for your code transformation.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
setexprfields, swak4foam |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
