chtMultiRegionFoam: two fluid regions separated by a thin, conducting wall
Old   April 23, 2021, 23:16
Unhappy chtMultiRegionFoam: two fluid regions separated by a thin, conducting wall
J.D. Wilson
JayDeeUU is on a distinguished road
I'd be grateful for any suggestions in relation to the following OpenFoam task, which is not covered by any of the tutorials relating to chtMultiRegionFoam. I expect what I'm attempting has been done by others, but I haven't chanced to find any forum entry or external tutorial that wholly covers it. Please note that the setup here is for 2D-axisymmetric calculations.
Attached Figures (1,2) show (in paraFoam) two (meshed) fluid regions, that had been generated using Gmsh. One, a sphere (radius 6 m) with an access neck, represents the Snoplus neutrino detector ("detector"), and is filled with a scintillator fluid (Gmsh physical volume name and OpenFoam region name "scintillator"). The other region represents a volume of water in the "cavity" surrounding the detector (Gmsh physical volume name and OpenFoam region name "water"). The underlying interest is to compute buoyancy-driven circulation of the scintillator fluid, whereas some earlier simulations have modelled only the detector volume. Coupling to the water volume will allow to use a measured profile of temperature to drive the scintillator circulation.
The domain shown by the figures was created by rotating/extruding two plane surfaces, each of which was defined by a loop in Gmsh: the loop that (when extruded) defines the outer edge of the detector forms (also) part of the loop defining an edge whose extrusion defines the cavity (this is evident from the figures). In reality detector and cavity (i.e. the eventual OpenFoam fluid regions "scintillator" and "water") are separated by a 5.5 cm thick plexiglass wall [note: I originally mis-stated this dimension as 2 cm, consistent with the four layers of 0.5 cm seen in files below], but I'm hoping to be able to represent this (conducting) barrier without actually meshing it - somewhat along the lines of a 2011 forum post https://www.cfd-online.com/Forums/openfoam-solving/80114-two-sided-wall-heat-transfer-bc-no-separate-solid-mesh-no-heat-transfer-coeff.html . Also relevant is the 2016 tutorial by Dr. Johann Turnow, https://www.foamacademy.com/wp-conte...out_public.pdf
For what follows, it will be useful to state the names (assigned in Gmsh) for various "physical surfaces", names which hopefully are self-explanatory. There are four physical surfaces whose corresponding OpenFoam patches are of the "wedge" type used in 2D-axisymmetric calculations, namely westface, eastface, westface_cavity and eastface_cavity. The outer boundary of the detector (scintillator) is defined by three faces: lid, sidewall_neck, sidewall_shell. And finally the boundary of the cavity (water) volme is defined partially by these latter three, and completed by surfaces lid_cavity, sidewall_cavity and base_cavity.
Having copied the mesh file (domain.msh) to a case folder, and having set up regionProperties
regions
    fluid       (water scintillator)
    solid       ()
with two fluid regions but no solid regions, I issued
gmshToFoam domain.msh
splitMeshRegions -cellZones -overwrite
The result of these commands was that in constant/polyMesh/boundary there are seven patches:
7
    westface
        type            wedge;
        physicalType    wedge;
        nFaces          10984;
        startFace       20578;
    westface_cavity
        type            wedge;
        physicalType    wedge;
        nFaces          2791;
        startFace       31562;
    eastface
        type            wedge;
        physicalType    wedge;
        nFaces          10984;
        startFace       34353;
    base_cavity
        type            wall;
        physicalType    wall;
        nFaces          4;
        startFace       45337;
    sidewall_cavity
        type            wall;
        physicalType    wall;
        nFaces          10;
        startFace       45341;
    lid_cavity
        type            wall;
        physicalType    wall;
        nFaces          4;
        startFace       45351;
    eastface_cavity
        type            wedge;
        physicalType    wedge;
        nFaces          2791;
        startFace       45355;
which together bound the union of the scintillator and water regions. In constant/water/polyMesh/boundary there are six patches,
6
    westface_cavity
        type            wedge;
        physicalType    wedge;
        nFaces          2791;
        startFace       4018;
    base_cavity
        type            wall;
        physicalType    wall;
        nFaces          4;
        startFace       6809;
    sidewall_cavity
        type            wall;
        physicalType    wall;
        nFaces          10;
        startFace       6813;
    lid_cavity
        type            wall;
        physicalType    wall;
        nFaces          4;
        startFace       6823;
    eastface_cavity
        type            wedge;
        physicalType    wedge;
        nFaces          2791;
        startFace       6827;
    water_to_scintillator
        type            mappedWall;
        inGroups        1(wall);
        nFaces          317;
        startFace       9618;
        sampleMode      nearestPatchFace;
        sampleRegion    scintillator;
        samplePatch     scintillator_to_water;
while in constant/scintillator/polyMesh/boundary there are only three patches:
3
    westface
        type            wedge;
        physicalType    wedge;
        nFaces          10984;
        startFace       16243;
    eastface
        type            wedge;
        physicalType    wedge;
        nFaces          10984;
        startFace       27227;
        type            mappedWall;
        inGroups        1(wall);
        nFaces          317;
        startFace       38211;
        sampleRegion    water;
        samplePatch     water_to_scintillator;
Here notice that three Gmsh physical surfaces, "lid, sidewall_neck" and "sidewall_shell", do not appear - having been compounded to make patches scintillator_to_water and water_to_scintillator.
I set up the boundaries in 0/scintillator/T as:
boundaryField
    westface
        type            wedge;
    eastface
        type            wedge;
        type compressible::turbulentTemperatureCoupledBaffleMixed;
        Tnbr T;
        //kappa fluidThermo;
        kappaMethod fluidThermo;
        kappaName none;
        value uniform 0;
        thicknessLayers (0.5e-2 0.5e-2 0.5e-2 0.5e-2); // four layers of .5 cm
        kappaLayers (0.19 0.19 0.19 0.19);
For present purposes specifying the thermophysicalProperties and other elements of the simulation is probably not warranted. The outcome is that when I run chtMultiRegionFoam I get warnings to the effect that "Wedge patch 'eastface' is not planar" (etc.), then (after various messages):
Creating finite volume options from "system/fvOptions"
Region: water Courant Number mean: 0 max: 0
Region: scintillator Courant Number mean: 0 max: 0
--> FOAM Warning :
    From bool Foam::functionObjects::vtkWrite::readSelection(const Foam::dictionary&)
    in file vtkWrite/vtkWriteUpdate.C at line 252
    No mesh regions selected for function object walls
deltaT = 0.001200048
Time = 0.00120005
Solving for fluid region water
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
My best guess is that I am not correctly handling the (unresolved, unmeshed) conductive wall (the patches scintillator_to_water and water_to_scintillator). I'd appreciate any suggestions. Thanks, John.
Last edited by JayDeeUU; April 27, 2021 at 09:41. Reason: Attachments were forgotten (forgot to close the selection window). Corrected thickness of plexiglass.
JayDeeUU is offline   Reply With Quote
Old   April 25, 2021, 16:21
Domenico Lahaye
dlahaye is on a distinguished road
Did you forget the attachments?
dlahaye is offline   Reply With Quote
Old   April 25, 2021, 16:43
J.D. Wilson
Thanks Domenico, yes I did forget.
Old   April 27, 2021, 04:18
Domenico Lahaye
1/ What is 0/water/T (just to make sure)?
2/ Is chtMultiRegionFoam confused because geometry/mesh definition assumes zero layer thickness whereas scintillator_to_water defines defines a non-zero thickness? It it valuable to try a run in which zero thickness in scintillator_to_water is assumed (as it should not take much)?
3/ I would like to understand the error message "wedge not planar" better than I currently do. I tried to extend a similar case (Sandia Flame D tutorial) with a solid domain and got the "wedge not planar" error. Possibly one should simplify the geometry is a first attempt.
Old   April 27, 2021, 09:38
Default Files in folder 0/...
J.D. Wilson
Thanks for your suggestions Domenico. I'll respond one-by-one:
1) 0/water/T was:
boundaryField
    westface_cavity
        type            wedge;
    eastface_cavity
        type            wedge;
        Tnbr T;
        kappaName none;
        value uniform 0;
    base_cavity
        type            fixedValue;
        value           uniform 290;
    sidewall_cavity
        type            fixedValue;
        value           uniform 290;
    lid_cavity
        type            fixedValue;
        value           uniform 290;
2) Following your suggestion, I amended the prescription for the (implicit) boundary patch (in both 0/scintillator/T and 0/water/T) to:
Tnbr T;
kappaName none;
value uniform 0;
thicknessLayers (0.0);
kappaLayers (1.e10);
When I ran the code again with this alteration again I got many warnings about non-planar wedge patches. Below I show only the final warning and the subsequent crash:
--> FOAM Warning :
    From virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBuffers&)
    in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72
    Wedge patch 'eastface' is not planar.
At local face at (4.6547833 0.20323223 3.5138368) the normal (-0.043619485 0.99904822 -1.811081e-09) differs from the average normal (-0.043619388 0.99904822 -2.125639e-11) by 9.4842994e-15
Either correct the patch or split it into planar parts
*** Reading fluid mesh thermophysical properties for region water
    Adding to thermoFluid
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState Boussinesq;
    specie          specie;
    energy          sensibleInternalEnergy;
3) Yes maybe I shall have to do some experimenting with a simpler domain. But right now I'm in the process of going in the opposite direction and making it more complicated... by resolving the plexiglass shell (5.5 cm thick - I mis-stated the thickness earlier) in Gmsh. I'll add to this post when I have some progress, positive or negative.
Thanks again!
Old   April 27, 2021, 10:30
Domenico Lahaye
Thx for your input.
The runtime error in your post #5 seems to be different than in your post #1. Is this correct? Is post #5 any progress over post #1? Is the solver in post #5 getting beyond a first solve on one of the solid domains?
Old   April 27, 2021, 11:25
J.D. Wilson
Yes, you're correct about there being a difference in outcome. With the original 4 layers the solver does report that it is "Solving for fluid region water", but not so in the altered case, that is, the solver in post #5 is not getting beyond a first solve on any of the regions.
I've re-run both setups, and I'll attach the log files. I inserted into the bottom of the log file the text that appeared in the terminal... and had to cut out a vast volume of the warnings (to reduce file size).
Old   April 29, 2021, 12:48
Default Update
J.D. Wilson
I've made some progress on this. I created the (wedge) mesh anew in Gmsh, this time resolving the plexiglass wall that separates scintillator from water. Then, starting with a new case folder that was empty but for
 /constant/regionProperties
/system/controlDict
/system/fvSolution
 /system/fvSchemes
and the .msh file, I ran "gmshToFoam" and then "splitMeshRegions -cellZones -overwrite" . I kept track of files that were newly created by these commands, and the naming of patches (some flowing from choices of names in Gmsh, some automatically generated). There were no problems.
I changed the patch names as necessary (e.g. for the bounding side planes of the wedge, type "wedge" is obligatory), copied back in the thermophysicalProperties files and so forth, and amended the 0/region/U,T etc. files. The program still crashed, with messages reporting the arising of absurd temperatures. Proceeding by trial and error I altered the "equationOfState" choice for the fluids from "Boussinesq" to "rhoConst" - the program runs only provided neither fluid is treated using the Boussinesq option. I've attached an image of the UZ field at t=100 s. Here the T field was initialized as being isothermal, so there is no reason for motion to develop, and indeed practically it does not. In the case shown I set nNonOrthogonalCorrectors to 5 (whereas if I set it to 1, the motion field is about 5 orders of magnitude more vigorous). One other point to note is that with this new mesh, resolving the plexiglass layer, the solver is not giving the warnings that had occurred with the original mesh ("Wedge patch 'eastface' is not planar, etc).
Going ahead the rhoConst option will not be suitable, so I will have to plug on and try to get the "Boussinesq" option to work, at least for the scintillator (it has been fine during months of work with other solvers). I'll pursue a more suitable formulation for the water (whose coefft. of thermal expansion of course varies strongly with temperature). In past work I've coded in a spatially-uniform "background" thermal stratification by including a term - \, w \, \partial T_{bg}/\partial z in the TEqn.H (where w is the vertical velocity UZ and \partial T_{bg}/\partial z is a positive constant, e.g. 0.2 [K/m]), and interpreting the T variable as a perturbation (acting on the motion through the buoyancy term). Then I can initialize with T isothermal, and force the flow by imposing a cool zone (in T) on the boundary. I'm hoping I may be able to do this here, too.
Finally, I've also revisited the case that initialized this post and discussion, which differs in that the solid zone was not meshed. I confess that I discovered the "fvSchemes" and "fvSolution" files for both regions, that I'd used in the attempts that triggered this entire post, were merely template files. With that oversight corrected, and with the "equationOfState" option "rhoConst" for both fluids, the solver now does run - albeit still with the warnings about non-planar faces. If I choose equationOfState as "Boussinesq" for either fluid, the solver crashes with huge negative temperature.
File Type: png snoplus25a_UZ_rhoConst_isothermal_nonOgcrctrs5_t100.png (39.4 KB, 18 views)
Last edited by JayDeeUU; April 29, 2021 at 14:04. Reason: Update (and confession).
Old   April 30, 2021, 13:33
Domenico Lahaye
This seems like wonderful progress!
Possibly you can try to bound rho (especially in early stage of convergence) to get Boussinesq to converge. Alternatively, you can try to provide an initial guess generated using rhoConst to Boussinesq.
I would like to gain an understand of what caused the non-planar faces warning.
Old   May 1, 2021, 12:44
Default Bad mesh and less-bad mesh in relation to solver's "non-planar face" warnings
J.D. Wilson
Thanks for the suggestions, which I'm going to try (to get Boussinesq to converge). I'll post the outcome. Regarding the cause of the non-planar faces warnings that arise when one runs the solver on the mesh (case "snoplus25") that does not mesh the plexiglass, here is an instance:
Create time
Create fluid mesh for region water for time = 0
--> FOAM Warning :
    Wedge patch 'westface_cavity' is not planar.
At local face at (6.1629055 -0.26907827 0.47202264) the normal (-0.043619405 -0.99904822 -4.4252931e-08) differs from the average normal (-0.043619387 -0.99904822 2.0481131e-10) by 2.3293888e-15
Next line was numbered 48516... i.e. screeds of these warnings
--> FOAM Warning :
Recall this is happening with a "wedge" type domain (azimuthal span \pm  2.5^{\circ}) for 2D-axisymmetric simulations, and it was produced in Gmsh. There's no way (so far as I can see) to inspect the mesh in Blender or MeshLab, because the mesh output format is .msh. The gmshToFoam command gives what is needed by OpenFoam, and the OF command "checkMesh -allTopology -allGeometry" indicates that this mesh fails two checks (see attached file "checkMesh_snoplus25.txt"). One can look at the mesh using paraFoam. What is odd is that in some views paraFoam displays spurious blotches (for want of a better word) - see attached image.
Comparing the above diagnostics with those pertaining to a similar mesh (case "snoplus25a") that DOES resolve (mesh) the plexiglass boundary and that DOES NOT generate the "non-planar'' warnings when the solver is run, checkMesh still flags one issue (see atttached file checkMesh_snoplus25a.txt), but, no matter how this domain is viewed in paraFoam, there are none of the oddities seen in case snoplus25.
Mesh_snoplus25_inParaFoam_internalMesh_PLUS_waterInternalMesh_scintInternalMesh_vtkBlockColors_n.png
Mesh_snoplus25a_inParaFoam_internalMesh_plusAll_plexiToWaterPatches_vtkBlockColors.png
Old   May 1, 2021, 12:49
Default The Gmsh file that created the bad mesh
  #11
J.D. Wilson
I have attached here the .geo file (renamed with extension .txt) corresponding to the bad mesh of case snoplus25 (plexiglass not meshed). It can be used to reproduce Gmsh's .msh file which can then be used with gmshToFoam.
Old   May 2, 2021, 13:49
Domenico Lahaye
Interesting.
I checked that the "not planar" error is given by the function Foam::symmetryPlanePolyPatch::calcGeometry with implementation here https://github.com/OpenFOAM/OpenFOAM...anePolyPatch.C
We should be able to loop over all the cells constituting the wedge patch, print the cell normal and see by how much they differ.
Old   June 6, 2021, 22:07
Default Setting "dpdt off" when using "equationOfState Boussinesq"
  #13
J.D. Wilson
In case this should help anyone encountering the difficulty described above (chtMultiRegionFoam crashing when fluid density is treated using the Boussinesq approximation), I have eventually stumbled on the recommendation (e.g. at http://www.wolfdynamics.com/training...F8/all-2x2.pdf ) to set "dpdt off" in the fluid thermophysicalProperties files - where, by the way, I have chosen:
thermo hConst;
energy sensibleEnthalpy;
This worked for me. It's the spirit of the Boussinesq approximation that absolute pressure is unimportant, only its gradients matter, and, density is a unique function of temperature.
Although I continue to have problems getting a wedge-type mesh (for 2D axisymmetric calculations) that passes "checkMesh -allTopology -allGeometry", one of many attempts does pass, and is adequate to at least progress with the project.
Old   July 21, 2021, 21:34
Declan Keogh
dkeogh is on a distinguished road
Hi J.D.,
Did you figure this problem out? I am currently running computations on an axisymmetric mesh which I then split and use in chtmultiregionfoam. When I use the mesh in the axisymmetric computations before splitting by region everything works fine. Once I split the mesh though I get the same "not planar" error message. It is possible for me to use a three-dimensional mesh but it would be much more computationally demanding...
dkeogh is offline   Reply With Quote
Old   July 22, 2021, 12:09
Default Wedge patch '<patch name>' is not planar...
  #15
J.D. Wilson
Hi, I don't have any new insights on that problem of the "not planar" messages, and my reply here is liable to be a bit unfocused, sorry. At the moment I'm not using chtMultiRegionFoam (I'm just focused on just one, central region), but I'll probably go back to it eventually.
One recent discovery (for me) is that after using "gmsgToFoam" one needs to set up the constant/polyMesh/boundary file before running checkMesh - on that score, in the past I must on some (but probably not all) occasions have wrongly concluded I had a bad mesh.
I think I also experienced that same (or a similar) message about surfaces not being planar when I used the "symmetryPlane" boundary condition on the bounding walls of a single-quadrant (rather than 5 degree wedge) mesh (also generated using Gmsh). I switched to using the "symmetry" condition instead, after reading the following forum discussion: symmetry and symmetryPlane boundary condition difference in OpenFOAM
Old   July 22, 2021, 20:28
Declan Keogh
Hi J.D.,
I managed to solve the problem although I have been using fluent to generate my mesh. I find that the problem seems to go away when I execute splitMeshRegions -cellZones -overwrite with a write precision of 20. I found that I had to change the write precision in controlDict before splitting the mesh. I did not have to change the writeFormat to binary as has been suggested in other posts. Also, I was able to keep the wedge boundary condition.
Old   July 22, 2021, 21:17
J.D. Wilson
Thanks Declan. Glad you've found a way around the problem.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 13:55
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
