Water level is raising as simulation progresses |
May 31, 2022, 09:31 |
Akshay
Rep Power: 6 |
I am conducting two-phase flow simulations in a separator with 3 inlets and 2 outlets using twoPhaseEulerFoam in OF version 8.
The inlet velocity BC is specified at 2 inlets and pressure outlet BC is specified at the 2 outlets. Initially, half of the separator volume is filled with water using setFieldDict. I am expecting the water level to remain constant but strangely the water level increases. I was expecting flow in = flow out, the velocity vector at the water outlet is not correctly calculating the water velocity at the outlet. I have attached my BC for U, p_rgh, alpha fields below. Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet1 { type fixedValue; value uniform 0.698; } inlet2 { type fixedValue; value uniform 0.698; } inlet3 { type fixedValue; value uniform 0.698; } walls { type zeroGradient; } baffle1 { type zeroGradient; } baffle2 { type zeroGradient; } baffle3 { type zeroGradient; } outlet1 { type inletOutlet; phi phi.water; inletValue uniform 1; value uniform 1; } outlet2 { type inletOutlet; phi phi.water; inletValue uniform 0; value uniform 0; } } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object alpha.oxygen; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 1; boundaryField { inlet1 { type fixedValue; value uniform 0.302; } inlet2 { type fixedValue; value uniform 0.302; } inlet3 { type fixedValue; value uniform 0.302; } walls { type zeroGradient; } baffle1 { type zeroGradient; } baffle2 { type zeroGradient; } baffle3 { type zeroGradient; } outlet1 { type inletOutlet; phi phi.oxygen; inletValue uniform 0; value uniform 0; } outlet2 { type inletOutlet; phi phi.oxygen; inletValue uniform 1; value uniform 1; } } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 4.01325e5; boundaryField { inlet1 { type fixedFluxPressure; value $internalField; } inlet2 { type fixedFluxPressure; value $internalField; } inlet3 { type fixedFluxPressure; value $internalField; } walls { type fixedFluxPressure; value $internalField; } baffle1 { type fixedFluxPressure; value $internalField; } baffle2 { type fixedFluxPressure; value $internalField; } baffle3 { type fixedFluxPressure; value $internalField; } outlet1 //water outlet { type prghPressure; p $internalField; value $internalField; } outlet2 //oxygen outlet { type fixedValue; value $internalField; } } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Code:
FoamFile { version 2.0; format binary; class volVectorField; object U.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet1 { type fixedValue; value uniform (0 0 3.83); } inlet2 { type fixedValue; value uniform (0 0 -3.83); } inlet3 { type fixedValue; value uniform (0 0 -3.83); } walls { type noSlip; } baffle1 { type noSlip; } baffle2 { type noSlip; } baffle3 { type noSlip; } outlet1 { type pressureInletOutletVelocity; phi phi.water; value $internalField; } outlet2 { type pressureInletOutletVelocity; phi phi.water; value $internalField; } } // ************************************************************************* // Code:
FoamFile { version 2.0; format binary; class volVectorField; object U.oxygen; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet1 { type fixedValue; value uniform (0 0 1.66); } inlet2 { type fixedValue; value uniform (0 0 -1.66); } inlet3 { type fixedValue; value uniform (0 0 -1.66); } walls { type fixedValue; value uniform (0 0 0); } baffle1 { type fixedValue; value uniform (0 0 0); } baffle2 { type fixedValue; value uniform (0 0 0); } baffle3 { type fixedValue; value uniform (0 0 0); } outlet1 { type pressureInletOutletVelocity; phi phi.oxygen; value $internalField; } outlet2 { type pressureInletOutletVelocity; phi phi.oxygen; value $internalField; } } // ************************************************************************* // out.0000.png out.0399.png Thank you. |
June 23, 2022, 02:40 |
I have modifies the boundary conditions
Akshay
Rep Power: 6 |
It is really difficult to maintain a water level inside the separator, I am playing with certain boundary conditions. Please let me know if my present adopted boundary condition is good.
{ version 2.0; format binary; class volVectorField; object U.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet1 { type fixedValue; value uniform (0 0 3.83); } inlet2 { type fixedValue; value uniform (0 0 -3.83); } inlet3 { type fixedValue; value uniform (0 0 -3.83); } walls { type noSlip; } pipes { type noSlip; } baffle1 { type noSlip; } baffle2 { type noSlip; } baffle3 { type noSlip; } outlet1 { type outletPhaseMeanVelocity; UnMean 3.07; alpha alpha.water; value uniform (0 0 0); } outlet2 { type zeroGradient; } } Code:
FoamFile { version 2.0; format binary; class volVectorField; object U.oxygen; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet1 { type fixedValue; value uniform (0 0 1.66); } inlet2 { type fixedValue; value uniform (0 0 -1.66); } inlet3 { type fixedValue; value uniform (0 0 -1.66); } walls { type noSlip; } pipes { type noSlip; } baffle1 { type noSlip; } baffle2 { type noSlip; } baffle3 { type noSlip; } outlet1 { type zeroGradient; } outlet2 { type pressureInletOutletVelocity; phi phi.oxygen; value $internalField; } } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 4.01325e5; boundaryField { inlet1 { type fixedFluxPressure; value $internalField; } inlet2 { type fixedFluxPressure; value $internalField; } inlet3 { type fixedFluxPressure; value $internalField; } walls { type fixedFluxPressure; value $internalField; } pipes { type fixedFluxPressure; value $internalField; } baffle1 { type fixedFluxPressure; value $internalField; } baffle2 { type fixedFluxPressure; value $internalField; } baffle3 { type fixedFluxPressure; value $internalField; } outlet1 { type fixedFluxPressure; value $internalField; } outlet2 { type fixedValue; value $internalField; } /* { type totalPressure; p0 $internalField; value $internalField; // Optional entries U U.oxygen; phi phi; rho rho; } */ } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Code:
Mesh stats points: 188392 faces: 539938 internal faces: 516140 cells: 176193 faces per cell: 5.99387 boundary patches: 10 point zones: 0 face zones: 7 cell zones: 0 Overall number of cells of each type: hexahedra: 164588 prisms: 7831 wedges: 0 pyramids: 0 tet wedges: 67 tetrahedra: 0 polyhedra: 3707 Breakdown of polyhedra by number of faces: faces number of cells 4 467 5 413 6 836 7 45 8 62 9 1230 10 15 11 11 12 475 13 5 14 4 15 127 16 3 18 14 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology baffle1 1686 1713 ok (non-closed singly connected) baffle2 1670 1702 ok (non-closed singly connected) baffle3 1684 1715 ok (non-closed singly connected) inlet1 59 67 ok (non-closed singly connected) inlet2 60 68 ok (non-closed singly connected) inlet3 57 63 ok (non-closed singly connected) outlet1 218 232 ok (non-closed singly connected) outlet2 16 18 ok (non-closed singly connected) pipes 1771 1985 ok (non-closed singly connected) walls 16577 17438 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.108 -0.348498 -0.4122) (2.8772 0.348494 0.4122) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-2.41681e-17 5.65559e-16 3.60538e-16) OK. Max cell openness = 2.84095e-16 OK. Max aspect ratio = 6.71026 OK. Minimum face area = 6.42656e-07. Maximum face area = 0.000725531. Face area magnitudes OK. Min volume = 5.69092e-08. Max volume = 1.11177e-05. Total volume = 1.04276. Cell volumes OK. Mesh non-orthogonality Max: 44.9781 average: 5.05001 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.95597 OK. Coupled point location match (average 0) OK. Mesh OK. End |
Solid object falling in water tank simulation | cassini83 | CFX | 3 | August 9, 2021 17:05 |
postProcessing to visualize areas touched by water during a sprinkling simulation | TheBigLebowski | OpenFOAM | 0 | August 1, 2021 10:20 |
Water level doesn't rise in CFD-DEM simulation of air-water-solid. What should I chec | gsiitd | OpenFOAM | 0 | January 23, 2019 00:25 |
For a single phase flow, is there any way to check water surface level? | Tanjina | FLUENT | 0 | February 23, 2014 22:56 |
