June 30, 2022, 07:13 |
surface tension error
Olabode Ajenifujah
Rep Power: 4 |
Hello, I got this error message while working with openfoam, Although I have looked at the constant file for the possible of the error, but I could not find it. Do I need to change something in the dictionaryTemplates.C
[0] --> FOAM FATAL IO ERROR: (openfoam-2112) [0] Entry 'type' not found in dictionary "/OpenFOAM/run/test/constant/phaseProperties.surfaceTension" [0] [0] [0] file: constant/phaseProperties.surfaceTension at line 132 to 153. [0] [0] From bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType:ption, bool) const [with T = Foam::word] [0] in file /home/OpenFOAM/OpenFOAM-v2112/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 322. [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [1] [1] [1] --> FOAM FATAL IO ERROR: (openfoam-2112) [1] Entry 'type' not found in dictionary "stream.surfaceTension" [1] [1] [1] file: stream.surfaceTension at line 0. [1] [1] From bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType:ption, bool) const [with T = Foam::word] [1] in file /home/OpenFOAM/OpenFOAM-v2112/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 322. [1] FOAM parallel run exiting [1] [2] [2] [2] --> FOAM FATAL IO ERROR: (openfoam-2112) [2] Entry 'type' not found in dictionary "stream.surfaceTension" [2] [2] [2] file: stream.surfaceTension at line 0. [2] [2] From bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType:ption, bool) const [with T = Foam::word] [2] in file /home/OpenFOAM/OpenFOAM-v2112/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 322. [2] FOAM parallel run exiting |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
