Execution of setFields changes boundary condition types
Old   May 21, 2019, 04:11
Default Execution of setFields changes boundary condition types
Sita Drost
sita is on a distinguished road
Dear all,
I'm playing around with the velocity ramping functionality for multiphase flows (OpenFOAM-dev, build dev-54cb927cee89, on Scientific Linux cluster).
At the moment I'm trying to adapt the DTCHull tutorial case to include a quarter sine velocity ramp at start-up. I've included the required fvOptions file in constant, adapted the simulation parameters to run a transient simulation (the original tutorial uses local time stepping), and added ramping to my inlet and outlet BCs in 0/U.
However, after running setFields, my outlet velocity ramping BC changes back to the original outletPhaseMeanVelocity, without velocity ramping. I've already removed all occurrences of #includeEtc "caseDicts/setConstraintTypes", but still my ramping BC keeps disappearing.
Surely there must be something very silly that I'm overlooking here, but right now I can't find it. Does anyone have experience with this?
Thanks in advance,
Sita
sita is offline   Reply With Quote
Old   May 21, 2019, 05:24
Default Solved
Sita Drost
Got it: I was using the wrong syntax for the velocity ramping BCs
Old   September 29, 2022, 04:07
Seyfi Girgin
seyfigirgin is on a distinguished road
Hi Sita,
How did you manage to do this. I want to apply setFields command without changing the boundary conditions also
seyfigirgin is offline   Reply With Quote
Old   September 29, 2022, 07:09
Sita Drost
Ouch, that was a long time ago; I changed jobs in the meantime...
I looked up some old code, here's the contents of the 0/u file, hopefully that'll help you:
|  \\    /   O peration     | Version:  5.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      binary;
    class       volVectorField;
    location    "0";
    object      U;
#include		"../constant/refValues";
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    // hull parts
	".*\$_s[0-9]_b[0-9]"
		type			movingWallVelocity;
		value			uniform (0 0 0);
	// symmetry plane
    _ymin
        type            symmetryPlane;
	// atmosphere
    _zmax
        type            pressureInletOutletVelocity;
	// outlet
    _xmin
        type            outletPhaseMeanVelocity;
        alpha           alpha.water;
        value           $internalField;
        UnMean
			value		$Uref;
			type		scale;
			scale
				type		quarterSineRamp;
				start		0;
				duration	$duration; //#calc	"400*$deltaT";
	// far side of box
    _ymax
        type            zeroGradient;
	// bottom of box
    _zmin
        type            zeroGradient;
	// inlet
    _xmax
		type            uniformFixedValue;
        uniformValue
			value		(#neg $Uref 0 0);
			type 		scale;
			scale
				start	0;
Old   September 29, 2022, 12:29
Seyfi Girgin
FoamFile
    version     2.0;
    format      binary;
    location    "0";
    object      U;
boundaryField
    // hull parts
	// symmetry plane
    _ymin
        type            symmetryPlane;
	// atmosphere
    _zmax
	// outlet
    _xmin
        alpha           alpha.water;
        UnMean
			value		$Uref;
			type		scale;
			scale
				start		0;
	// far side of box
    _ymax
        type            zeroGradient;
	// bottom of box
    _zmin
        type            zeroGradient;
	// inlet
    _xmax
        uniformValue
			type 		scale;
			scale
				start	0;
Is this your original U file or modified U file to protect your BCs. What did you add to this original U file i don't understand.
Old   September 29, 2022, 14:25
Sita Drost
Usually you start by saying something like, hey, thanks for trying to help!
But anyway, this is the original 0/U file, with a working velocity ramping BC at _xmin. The code at the beginning, under // hull parts, contains regex to refer to different hull parts in the mesh file. As I mentioned earlier, I changed jobs in the meantime, so I don't exactly remember all the details of this, and can't test if the file still works under the current version of OpenFOAM. Hope this helps.
P.S. This 0/U file is not the one for the DTCHull tutorial case, but for a very similar ship simulation, hence the different names, but the velocity ramping BC at the domain inlet (called _xmin here) is the same.
Cyclic boundary condition in foam-extend 4.0 rellumeister OpenFOAM Pre-Processing 2 March 3, 2020 08:03
Constant mass flow rate boundary condition sahm OpenFOAM 0 June 20, 2018 22:45
Changing Boundary Condition Types via Scheme/UDF RTN3000 Fluent UDF and Scheme Programming 6 November 3, 2015 16:28
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
