April 12, 2023, 03:17 |
Setfields
Arpit Singh
Rep Power: 3 |
I want to give a temp. (1500K) to a specific region for say 5 sec. With the help of set fields I am able to give this temperature for starting the simulation (t=0) but not for a time period. Can anyone suggest some approach? I have attached an image of the same.
April 12, 2023, 03:41 |
Rep Power: 5 |
Hey,
This fvOptions function might help you: https://www.openfoam.com/documentati...onstraint.html Not sure how to set the duration though, other fvOptions have sometimes a duration so try that, or see if a table for the T field could work maybe. Or just manually disable the function at T=5sec. A script could do the trick. Good luck |
openfoam 10, reactingfoam, setfielddict, temperature |
Manual decomposition using setFields | RL-S | OpenFOAM Pre-Processing | 8 | July 3, 2023 08:51 |
setFields problems | Konstantinos | OpenFOAM Pre-Processing | 2 | April 18, 2021 05:25 |
Wierd results after running setFields without getting an error in terminal | vava10 | OpenFOAM Pre-Processing | 3 | January 15, 2021 11:12 |
rhoSimplecFoam with setFields | sino75 | OpenFOAM Pre-Processing | 0 | March 11, 2015 04:08 |
Problems with the execution of the setFields utility. | foamer | OpenFOAM Pre-Processing | 5 | June 3, 2013 12:24 |
