searchableSurface to solid body... is it possible?
Old   May 25, 2023, 13:35
Default searchableSurface to solid body... is it possible?
Jairo A. Gutiérrez S
jairoandres is on a distinguished road
Dear OpenFOAM users
I'm looking to quickly construct (maybe using a script) a PCB for thermal analysis in OpenFOAM. While constructing the simplified CAD and splitting the STL faces is always an option, I wonder if it is possible to do it using searchableSurfaces (as this class contains all the primitive shapes I need for the simplified model).
I have previously used searchableSurfaces to set cell value properties within the mesh or to construct baffles; however, I have been researching if it is possible to treat a searchableSurface as an STL-solid in snappyHexMesh (or using any special cellSet to XXXX function) to generate a solid within a fluid domain, with its own boundary conditions, thermophysical properties, and meshing assignments.
Thank you all for your support,
Regards,
Jairo.
jairoandres is offline   Reply With Quote
Old   May 26, 2023, 03:21
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Jairo,
I don't know if I correctly understand your question, but in snappyHexMesh, searchableSurfaces and STL are both geometric entities, so you can use searchableSurfaces the same way you would use a STL file.
Regards,
Yann
Yann is offline   Reply With Quote
Solid Body Motion Lynus Autodesk Simulation CFD 0 September 7, 2015 05:30
How to visualize the solid body in multiphase flow grid? asoltoon OpenFOAM Post-Processing 2 February 2, 2013 12:40
Re-meshing a deformable solid body in a fluid brashear CFX 6 December 12, 2011 11:13
Why the body is solid but not fluid when the NX file import into the DM? ddx ANSYS Meshing & Geometry 1 December 27, 2010 22:13
cooling a solid body Ralf Schmidt FLUENT 1 April 16, 2007 10:54
