simulation of rigid solid falling in a tank of water in OverInterDyMFoam
Like Tree1Likes
  • 1 Post By Maya3
Old   June 30, 2023, 07:21
Default simulation of rigid solid falling in a tank of water in OverInterDyMFoam
Mayank
Maya3 is on a distinguished road
I am pretty new to CFD. I am trying to modify the floatingBody tutorial in the overInterDyMFoam solver of OpenFOAM-v2212 to simulate a rigid solid body falling in a tank of water. To do so, I have increased the size of domain a little in the blockMesh file, adjusted setFields to have water level a little below the solid( floatingObject patch ). Also, I have increased the value of rhoSolid to 2700( density of rock) in the dynamicMeshDict file.
With this setup I was hoping that the whole background mesh will serve as the tank with the patch stationaryWalls serving as the walls of tank and the solid defined in overset mesh will fall to the bootom surface of this tank.
But, when I run my simulation after these changes, there are 2 problems:
(i) When the solid body reaches the bottom surface, it does not collide and stop there. The solid moves right through the bottom face and moves out of the domain defined in blockMesh of background mesh. I don't know if this a feature of Overset meshes. Is there a way to make it stop at the bottom surface and keep it inside the defined domain only.
(ii) The solid moves in oscillatory fashion in the vertical direction just like a piston. It is similar to how it is in the original tutorial simulation of floatingBody. On changing the density of the body the magnitude of oscillation increases. I have tried commenting out all the constraints in the dynamicMeshDict file, but it did not help. If you could tell me how to change the motion into a simple free fall or where this oscillatory motion is defined, it would be a great help.
I have attached an image of solid moving out of domain.
cfdberkeley likes this.
Maya3 is offline   Reply With Quote
Old   November 12, 2023, 10:23
Default question
Kazakis Ioannis
Giannis_Kaz is on a distinguished road
Dear Maya
I am very interested in your case. How do you manage the stability of the case? I am doing exactly the same but unfortunately the simulation crashes in first time steps
Kind regards
Yiannis
Giannis_Kaz is offline   Reply With Quote
ANSYS Fluent rotation of SOLID drum filled with water coms0 FLUENT 0 October 26, 2019 10:49
to make a air bubble in a water tank simulation harshrox3 FLUENT 0 November 8, 2015 16:12
Keeping inlet mass flux the same as outlet mass flux in an water tank vaibhav402 Main CFD Forum 0 October 13, 2015 04:02
simulation of free falling sphere into calm water? pedyspider CFX 17 June 25, 2015 12:03
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
