SnappyHexMesh: topoSetDict and createPatch fatal error |
July 4, 2023, 00:27 |
Maxence
Hi people, newbie here!
I am following this OpenFOAM Intermediate tutorial: https://www.youtube.com/watch?v=sIU1...i_iuE&index=15 to learn how to use the snappyHexMesh utility for a personal project, and I am stuck on topoSetDict and createPatch. I followed the tutorial step by step, the only difference is the original 3D file used, but when I try to execute the createPatch function to define my inlet, outlet and walls patches, I get an error: Read 73995 faces from faceSet inputPatch --> FOAM FATAL ERROR: (openfoam-2012) Face 26766 specified in set inputPatch is not an external face of the mesh. This application can only repatch existing boundary faces. From int main(int, char**) in file createPatch.C at line 743. FOAM exiting I am not sure what the issue is, as I don't understand what I could change to generate the different patches for the simulation. What is a non-external face? Is it an internal face or not a face at all? Then how am I supposed to define the patches? Here is the mesh in Paraview (this is the shape that I want to study): https://ibb.co/gMPCLyg Also, I am not sure why there is a box surrounding my mesh when I change the visible patches (i did not make that box and don't know why it is here). Is that what is causing the problem? The actual mesh I want is internal? I don't know what that means halp. https://ibb.co/swQqdjs Here is the topoSetDict file used: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version2.0; formatascii; classdictionary; objecttopoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( // OUTER BOX { nameouterBox; typefaceSet; actionnew; sourcepatchToFace; sourceInfo { patch"movingWall"; } } { nameouterBox; typefaceSet; actionadd; sourcepatchToFace; sourceInfo { patch"fixedWalls"; } } { nameouterBox; typefaceSet; actionadd; sourcepatchToFace; sourceInfo { patch"frontAndBack"; } } // FULL CHIP { namechipBottomChannel; typefaceSet; actionnew; sourceboxToFace; sourceInfo { box (-3.1-14.0-0.7) (3.114.01.9); } } { namechipBottomChannel; typefaceSet; actiondelete; sourcefaceToFace; sourceInfo { setouterBox; } } // NEGATIVES { nameinputPatchNegative; typefaceSet; actionnew; sourceboxToFace; sourceInfo { boxes ( (-3.1-13.6-0.7) (3.113.61.4) (-3.1-14.01.0) (3.1-12.01.9) ); } } { nameoutputPatchNegative; typefaceSet; actionnew; sourceboxToFace; sourceInfo { boxes ( (-3.1-13.6-0.7) (3.113.61.4) (-3.112.01.0) (3.114.01.9) ); } } /*new faceSet => INPUT PATCH*/ { nameinputPatch; typefaceSet; actionnew; sourcefaceToFace; sourceInfo { setchipBottomChannel; } } { nameinputPatch; typefaceSet; actiondelete; sourcefaceToFace; sourceInfo { setinputPatchNegative; } } /*new faceSet => OUTPUT PATCH*/ { nameoutputPatch; typefaceSet; actionnew; sourcefaceToFace; sourceInfo { setchipBottomChannel; } } { nameoutputPatch; typefaceSet; actiondelete; sourcefaceToFace; sourceInfo { setoutputPatchNegative; } } /*new faceSet => WALLS*/ { nameWall; typefaceSet; actionnew; sourcefaceToFace; sourceInfo { setchipBottomChannel; } } { nameWall; typefaceSet; actiondelete; sourcefaceToFace; sourceInfo { setinputPatch; } } { nameWall; typefaceSet; actiondelete; sourcefaceToFace; sourceInfo { setoutputPatch; } } ); Thanks a lot for your help, I am new to CFD and this is all very confusing, ~~ Oreste |
createpatchdict, snappyhexmesh, toposetdict |
[Other] [cfMesh] Error when creating AMI patches propeller | gabrielfelix | OpenFOAM Community Contributions | 2 | July 5, 2023 20:54 |
Error in createPatch | gmori | OpenFOAM Pre-Processing | 2 | December 15, 2022 03:33 |
There is a bug in createPatch? | feno102 | OpenFOAM Pre-Processing | 6 | November 1, 2017 02:24 |
[snappyHexMesh] SnappyHexmesh error | yiwang25 | OpenFOAM Meshing & Mesh Conversion | 3 | June 16, 2013 16:07 |
