createBaffles -overwrite cause boundary condition disappear |
September 10, 2023, 06:36 |
Huang, Ching-Chan
Rep Power: 3 |
When I used createBaffles -overwrite the boundary condition about inlet and outlet in file 0 will disappear and replace by AMI1, AMI0. How to solve it.
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object createBafflesDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Whether to convert internal faces only (so leave boundary faces intact). // This is only relevant if your face selection type can pick up boundary // faces. internalFacesOnly true; // Baffles to create. baffles { rotating { //- Use predefined faceZone to select faces and orientation. type faceZone; zoneName face_inner_volume; //zoneName cell_inner_volume; //zoneName inner_volume; patches { master { //- Master side patch name AMI1; type cyclicAMI; matchTolerance 0.0001; neighbourPatch AMI2; transform noOrdering; //OF7 < //transform none; //OF8 and up } slave { //- Slave side patch name AMI2; type cyclicAMI; matchTolerance 0.0001; neighbourPatch AMI1; transform noOrdering; //OF7 < //transform none; //OF8 and up } } } } // ************************************************************************* // Code:
Create time --> FOAM Warning : From static Foam::IOstreamOption::compressionType Foam::IOstreamOption::compressionEnum(const Foam::word&, Foam::IOstreamOption::compressionType) in file db/options/IOstreamOption.C at line 115 Unknown compression specifier 'uncompressed', using compression off Create mesh for time = 0 Reading baffle criteria from createBafflesDict Not converting faces on non-coupled patches. Reading geometric fields Reading volScalarField: cellToRegion k nut omega p Reading volVectorField: U Created zone rotating at index 1 with 86239 faces Converted 2664 faces into boundary faces in patches 2(AMI1 AMI2) --> FOAM Warning : From int main(int, char**) in file createBaffles.C at line 865 Setting field on boundary faces to zero. You might have to edit these fields. Writing mesh to 0 End Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { walls { type fixedValue; value uniform (0 0 0); } defaultFaces { type empty; } airfoil { type rotatingWallVelocity; origin (0 0.025 0); axis (0 0 1); omega constant 12.56637; value uniform (0 0 0); } inlet { type fixedValue; value uniform (0 0 0); } outlet { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 04:13 |
