SnappyhexMesh warning errors (I wish to eliminate them! completely!)
Old   November 14, 2023, 07:24
Default SnappyhexMesh warning errors (I wish to eliminate them! completely!)
Biku
Biku is on a distinguished road
So I am learning snappyhexmesh. I am able to get a decent looking mesh but I get the following warning errors during the SHM process. I have not turned on the layers addition just yet.
--> FOAM Warning :
From function Foam::treeBoundBox::treeBoundBox(const Foam::UList<Foam::Vector<double> >&)
in file meshes/treeBoundBox/treeBoundBox.C at line 135
or
-->  FOAM Warning : Displacement (1.40188e-06 -1.34616e-06 -1.30598e-13) at  mesh point 6658 coord (0.0191844 -0.0654924 0.755) points through the  surrounding patch faces
I am not able to make grids ariund simple cylinders using SHM without either of those warning popping up! I have been trying for 2 weeks but the number SHM iterations I have run is very less due to resource limitations. So I request you guys to advice me.
The generated mesh does look decent but I want to turn off these warnings and want to know what causes them. Some good pracitices to follow etc. I have yet to dwell into complex stls.
I have attached my test case on which I am learning. Using OF 5.x.
https://drive.google.com/drive/folde...usp=drive_link
Biku is offline   Reply With Quote
Old   November 14, 2023, 08:03
Biku
received the treeboundbox warning when doing the snappy in parallel. The displacement error is when I do a serial execution of snappyhexmesh .
snappyhexmesh
Caffa 3D code Waliur Rahman Main CFD Forum 0 May 29, 2018 00:53
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Warning 097- AB Siemens 6 November 15, 2004 04:41
