Expressions syntax for vector component
Like Tree2Likes
  • 2 Post By ginop
Old   November 22, 2023, 05:54
Default Expressions syntax for vector component
Gino Parisella
ginop is on a distinguished road
I am trying to use expressions to set up initial conditions, but I have syntax issues to get components from vectors.
Example:
HTML Code:
var1 #eval { vector(1, sqrt(2), 3) };
var2 #eval { vector(var1.x(), 4, 5) };
the syntax above is not correct, and I tried a few variations of it without luck.
the resulting error is "Object var1.x does not exist or wrong type in expression at position...".
What is the correct syntax to use a component out of a defined vector?
Thank you in advance
ginop is offline   Reply With Quote
Old   December 5, 2023, 11:21
Default need to expand the string
Gino Parisella
ok, I found the answer in the user guide
basically if I define a vector
var1    #eval{vector(1, 5, 3)};
the vector components are accessed using the expansion
$[(vector) var1]
for example if I want to define another vector using the "y" component from "var1", I should do
var2    #eval{vector(4, $[(vector) var1].y(), 6)};
hope it helps!
Cheers
UDF syntax error Ratel Fluent UDF and Scheme Programming 4 May 23, 2015 06:15
what is syntax error : missing ')' before ';' aleisia Fluent UDF and Scheme Programming 8 March 10, 2015 16:42
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
