January 6, 2024, 10:01 |
'div((nuEff*dev2(T(grad(U)))))' not found?
Udit S Rao
Hello!
I am a beginner in OpenFOAM and I have just attempted to complete an analysis by my own (using pimpleFoam/pisoFoam). I have created my own mesh (~10^5 cells) and have all the necessary calculations ready. I filled the '0' folder files with the necessary initial conditions but while running pimpleFoam or pisoFoam, it gives me this error: Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes No MRF models present No finite volume options present Courant Number mean: 1.79393 max: 501.077 Courant Number mean: 1.79393 max: 501.077 Starting time loop Courant Number mean: 1.79393 max: 501.077 Time = 0.5 PIMPLE: iteration 1 --> FOAM FATAL IO ERROR: (openfoam-2312) Entry 'div((nuEff*dev2(T(grad(U)))))' not found in dictionary "system/fvSchemes/divSchemes" file: system/fvSchemes/divSchemes at line 29 to 30. From const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, Foam::keyType:ption) const in file db/dictionary/dictionary.C at line 363. FOAM exiting I have kept the time step a bit large because I just want it to run at first, then I will make the time step finer. Also my courant number is shooting up to a lot. I might have made some rookie mistakes, so kindly point them out to me. Thank you! |
January 6, 2024, 15:18 |
ONESP-RO
Rep Power: 5 |
Inside the divSchemes dictionary in the file system/fvSchemes, add this line:
div((nuEff*dev2(T(grad(U))))) Gauss linear;
Don't keep making the same mistakes. Try to make new mistakes. |
January 6, 2024, 15:47 |
Udit S Rao
I did it... but now its giving me a new error...
Create time Create mesh for time = 0 PISO: Operating solver in PISO mode Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes No MRF models present No finite volume options present Starting time loop Time = 0.5 Courant Number mean: 1.79393 max: 501.077 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 4.5122e-06, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 1.41181e-06, No Iterations 5 smoothSolver: Solving for Uz, Initial residual = 0.000661307, Final residual = 7.04702e-07, No Iterations 2 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0438961, No Iterations 141 DICPCG: Solving for p, Initial residual = 0.00681152, Final residual = 0.000245953, No Iterations 14 DICPCG: Solving for p, Initial residual = 0.000419764, Final residual = 1.64264e-05, No Iterations 144 time step continuity errors : sum local = 0.0404384, global = -0.000684349, cumulative = -0.000684349 DICPCG: Solving for p, Initial residual = 0.00646432, Final residual = 0.000214823, No Iterations 144 DICPCG: Solving for p, Initial residual = 0.00591995, Final residual = 0.000231605, No Iterations 14 DICPCG: Solving for p, Initial residual = 0.000404036, Final residual = 9.95925e-07, No Iterations 161 time step continuity errors : sum local = 0.00128751, global = 2.78271e-06, cumulative = -0.000681566 ExecutionTime = 0.25 s ClockTime = 0 s Time = 1 Courant Number mean: 1015.83 max: 3220.46 [stack trace] ============= #1 Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #2 ? in /lib/x86_64-linux-gnu/libc.so.6 #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #6 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so #7 Foam::fvMesh::solve(Foam::fvMatrix<Foam::Vector<do uble> >&, Foam::dictionary const&) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so #8 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/pisoFoam #9 ? in /lib/x86_64-linux-gnu/libc.so.6 #10 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #11 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/pisoFoam ============= Floating point exception The courant number is 1k.... Last edited by uditrao04; January 6, 2024 at 15:48. Reason: forgot to type it |
error, pimplefoam, pisofoam |
[RapidCFD] Discussion thread on how to install and use RapidCFD | newoscar | OpenFOAM Community Contributions | 88 | May 17, 2024 09:39 |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
