MRF-Boundary Condition U and equivalent for SRF Urel
Old   March 4, 2024, 15:09
Smile MRF-Boundary Condition U and equivalent for SRF Urel
Daniel
dnl_xr is on a distinguished road
Hei,
i have a hard time bc I have to do a MRF and a SRF Simulation of a pump turbine- in my MRF my U look like this:
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    IF_LAUF_LEIT
	type            cylindricalInletVelocity;
        axis            (0 0 1);
        origin          (0 0 0);
        axialVelocity   constant 0;
        radialVelocity  constant -10;
        rpm             constant 800;;
        value           uniform (0 0 0);
    IF_LAUF_SAUGROHR
	type            zeroGradient;
    "(cP_cyclicA|cP_cyclicB)"
        type            cyclic;
    "(NABE|KRANZ|SCHAUFEL)"
        type            fixedValue;
	value		uniform (0 0 0); //Wenn hier alle 3 Null stehen dann dreht es sich mit omega
the simulation looks goof to me. But I don't understand what the radial component exactly is. is the 10 m/s a velocity in Cartesian or cylindrical components? I think in cylindrical bc you have to define axial and radialvelocity. How can I understand the 10 m/s in radial direction? is this an absolut velocity or a relativ?
how can I find the equivalent for Urel for the SRF simulation.
I found this in on of the tutorials
boundaryField
    IF_LAUF_LEIT
        type            SRFVelocity;
	inletValue      uniform (-10 0 0);
	relative        no;
everything else stays the same as in the MRF.
what exactly is the inlet value? and do I need to put relativ yes or no?
To compare both simulation I need equal BC... But I don't understand if the SRFVelocity Vektor is in cartesian coordinates or also in cylindrical like the BC at the MRF ?
Can someone help me please...
dnl_xr is offline   Reply With Quote
multi reference frame, openf, single reference frame
Boundary condition to simulate X meters of pipe ERodriguez OpenFOAM Running, Solving & CFD 1 May 23, 2023 09:14
Boundary condition: solidTraction question bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 5 September 7, 2020 06:00
Equivalent of fully-developed boundary condition in polar coordinate mostanad Main CFD Forum 21 February 23, 2019 06:36
movingWallVelocity boundary condition kkpal OpenFOAM Running, Solving & CFD 0 October 15, 2016 10:12
time vary boundary condition to simulate waves in interFoam or equivalent haze_1986 OpenFOAM Running, Solving & CFD 0 June 9, 2014 03:27
