What does this Mapfield error "Unable to set source and target faces" mean?
Old   April 18, 2024, 13:47
Default What does this Mapfield error "Unable to set source and target faces" mean?
maxning is on a distinguished road
I was using a case that takes the result of another case as the initial condition and mapped to this one. But then this error happened:
Mapping initial flow data to the current simulation
--> FOAM FATAL ERROR:
From function void Foam::faceAreaWeightAMI<SourcePatch, TargetPatch>::setNextFaces(label&, label&, label&, const boolList&, labelList&, const DynamicList<label>&, bool) const
in file lnInclude/faceAreaWeightAMI.C at line 300.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::faceAreaWeightAMI<Foam::PrimitivePatch<Foam: :face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::calcAddressing(Foam::List<Foam:ynamicList<int , 0u, 2u, 1u> >&, Foam::List<Foam:ynamicList<double, 0u, 2u, 1u> >&, Foam::List<Foam:ynamicList<int, 0u, 2u, 1u> >&, Foam::List<Foam:ynamicList<double, 0u, 2u, 1u> >&, int, int) at ??:?
#3 Foam::faceAreaWeightAMI<Foam::PrimitivePatch<Foam: :face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::calculate(Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, int, int) at ??:?
#4 Foam::AMIInterpolation<Foam::PrimitivePatch<Foam:: face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::update(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:?
#5 Foam::meshToMesh::calculatePatchAMIs(Foam::word const&) at ??:?
#6 Foam::meshToMesh::constructNoCuttingPatches(Foam:: word const&, Foam::word const&, bool) at ??:?
#7 Foam::meshToMesh::meshToMesh(Foam:olyMesh const&, Foam:olyMesh const&, Foam::meshToMesh::interpolationMethod const&, bool) at ??:?
#8 ? at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? at ??:?
Aborted (core dumped)
Mapping - completed
Is it because of face naming issue, solver issue, or something else?
maxning is offline   Reply With Quote
Old   December 2, 2025, 12:11
John Heildern
CFD-Jesus is on a distinguished road
Were you able to fix the issue? I am getting the same error only after switching from SA to kEpsilon turbulence model. Everything worked fine with SA so I am not sure what is causing this issue.
CFD-Jesus is offline   Reply With Quote
Old   December 2, 2025, 14:16
Default help
adjbh
shbcj35 is on a distinguished road
Can u please tell how to attach hub shroud etc over a stator blade?
shbcj35 is offline   Reply With Quote
map fields, mapfields, mapfileds, source face
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
