November 20, 2007, 05:39 |
hi everybody
i try to crea
hi everybody
i try to create internalls walls in OF thanks to this thread: http://openfoamwiki.net/index.php/Howto_importing_fluent_mesh_with_internal_wall s i create my mesh with gambit but when i convert fluent mesh to openfoam it say me "Patch internal is internal to the mesh and is not being added to the boundary." but it don't create a set to use after splitmesh what am i doing wrong? what is the easy way to create a faceset ? bestregards |
November 20, 2007, 07:06 |
With the new versions of fluen
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
With the new versions of fluentMeshToFoam (1.4+ I think) you have to explicitly trigger the writting of the sets with the -writeSets-option.
It has been asked before here. I will modify the Wiki-page accordingly Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
November 20, 2007, 07:24 |
thanks bernhard
thanks bernhard
November 20, 2007, 07:47 |
sorry but i have got this erro
sorry but i have got this error
Create polyMesh for time = 0 #0 Foam::error::printStack(Foam:stream&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xffffe420] #3 Foam::polyMesh::initMesh() in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::polyMesh::polyMesh(Foam::IOobject const&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #5 main in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/splitMesh" #6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #7 Foam::regIOobject::write() const in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/splitMesh" Erreur de segmentation (core dumped) i suppose it's because startface like it say in the wiki What mean "current number of faces" for the startface on the wiki?where i can found it? best regards |
November 20, 2007, 07:59 |
Have a look at the faces-file
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Have a look at the faces-file in polyMesh. At the start of the list it says how many faces are in the list. This is the "current number of faces". Use it for the startFace.
November 20, 2007, 09:04 |
Alternatively, you can try to
Francesco Del Citto
Rep Power: 18 |
Alternatively, you can try to use fluent3DMeshToFoam shipped with OF 1.4.1.
If the internal walls are correctly set up in Fluent (i.e., with a Shadow face), it should be able to convert the mesh. Francesco |
December 5, 2007, 08:35 |
Hi!
I have a GAMBIT mesh wi
Mads Reck
Rep Power: 17 |
Hi!
I have a GAMBIT mesh with internal walls. I have exported it to a Fluent .msh file, which reads nicely into Fluent. I want it into OpenFOAM. It works beautifully if I do nothing, but naturally the internal walls are missing from the simulation. So, I did the fluentMeshToFoam . <case> <meshfile.msh> -writeSets fluentMeshToFoam recognises the internal walls but skips them, as noted by the original poster: "Patch internal is internal to the mesh and is not being added to the boundary." I have multiple internal walls, defined as separate BC's in Gambit. I am trying to just get one of them active. So, in the boundary-file I add two entries: InternalA { type wall; nFaces A; startFace B; } InternalB { type wall; nFaces A; startFace B; } I do not think that the question of what values to put A and B to, is clearly defined anywhere, or in the wiki. It is not clear to ignorant little me, at least. I run the command splitMesh . <case> <gambit_bc_name> InternalA InternalB and it gives various error messages, depending on what values A and B have. Hence I have some questions, and please be accurate and comprehensible :-) Question 1: I guess A and B has to be the same in InternalA and in InternalB, right? Question 2: what should A be set to? Question 3: what should B be set to? I tried to set A to the first number which occurs in the sets/<gambit_bc_name> file. Makes no sense to me, as splitMesh should be able to read this number. I tried to set B to the first number which occurs in the faces-file (just after the header). I believe this is the total face count. Makes no sense to me, why I should be using that number, as it should be available to splitMesh already from the faces-file. Makes no sense, meaning that I do not understand at all what numbers should go in A and B. Any help is greatly appreciated, thanks a bunch! /Mads I got a sets-directory in my polyMesh directory. |
December 5, 2007, 08:54 |
Hi Mads,
Have you tried flu
Christian Winkler
Rep Power: 17 |
Hi Mads,
Have you tried fluent3DMeshToFoam, this should do it. Best regards Christian |
December 6, 2007, 03:51 |
Hi Christian,
fluent3dMeshT
#9 |
Mads Reck
Rep Power: 17 |
Hi Christian,
fluent3dMeshToFoam never worked for me. But, slightly embarrassed I admit, that fluentMeshToFoam now works, it seems. Well, actually it still breaks, but now it ends on "new cannot satisfy memory request". The mesh is probably too big. I have plenty of RAM so I wonder if changing to the 64bit version will alleviate this...? Just, to clarify, since I may have caused some confusion, entries in the boundary file should read something like this: InternalA { type wall; nFaces 0; startFace <facecount>; } InternalB { type wall; nFaces 0; startFace <facecount>; } where <facecount> is the total number of faces, found in the file ./<case>/constant/polyMesh/faces as the first entry after the header. I have two follow-up questions, then. Q1: will 64-bit version alleviate the memory limit-issue? Q2: is fluent3DMeshToFoam the preferred choice? Thanks! /Mads |
December 6, 2007, 09:35 |
I had the same problem - I sho
#10 |
Paul Mauk
Rep Power: 17 |
I had the same problem - I should import a fluent-mesh with an internal wall. This never worked with fluentMeshToFoam, but after reading these messages I've tried fluent3DMeshToFoam - and I have to confirm - it works perfectly!!
December 10, 2007, 05:14 |
A quick hint on having multipl
#11 |
Mads Reck
Rep Power: 17 |
A quick hint on having multiple internal walls (i.e. defined in each own BC set)?
Do I run splitMesh multiple times or do I have to include all internals in one BC set in Gambit? /Mads |
Use wall function on some walls (not all walls) | Mahdi10 | FLUENT | 1 | February 16, 2009 11:52 |
HTC for low Y+ walls | Tang | FLUENT | 0 | March 15, 2007 15:55 |
how to cluster walls | prc | Siemens | 2 | December 26, 2006 03:56 |
too many walls?? | matze | Siemens | 2 | March 1, 2006 07:13 |
Thermal B.C at walls | Riham | FLUENT | 3 | January 27, 2004 13:57 |
