Normal to boundary velocity
Like Tree4Likes
  • 2 Post By mattijs
  • 2 Post By alberto
Old   January 21, 2006, 19:39
Default I have to model a pipe with a
Alberto Passalacqua
I have to model a pipe with a circular corona inlet all around the pipe circumference.
I have to specify a velocity normal to this boundary. How can I do it in OpenFOAM?
Thanks in advance
Alberto
Alberto Passalacqua
Old   January 23, 2006, 04:30
Default surfaceNormalFixedValue (in Op
Mattijs Janssens
surfaceNormalFixedValue (in OpenFOAM/lnInclude/surfaceNormalFixedValueFvPatchField.H)
needs a 'refValue' entry which is the outwards pointing velocity (so negative for inflow)
Rojj and RjwV like this.
Old   January 23, 2006, 17:30
Default Thanks!
Alberto Passalacqua
Thanks!
Alberto Passalacqua
Old   June 21, 2007, 10:12
Default Hi, it seems that I have a
Fabian Braennstroem
braennstroem is on a distinguished road
it seems that I have a similar problem... I would like to calculate a hvac duct and have to set the inlet velocity normal to the boundary. Unfortunately, I do not understand, what Mattijs wrote as a hint!?
Regards!
Fabian
braennstroem is offline   Reply With Quote
Old   June 21, 2007, 14:11
Default If the boundary is flat, use f
Alberto Passalacqua
If the boundary is flat, use fixedValue and specify the appropriate components of the velocity.
If it's not flat You can use:
type surfaceNormalFixedValue;
refValue uniform Umag;
As Mattijs said, if you want your flow to enter your domain, Umag has to be negative.
Regards,
Alberto
prashantsonakar and RjwV like this.
Alberto Passalacqua
Old   June 22, 2007, 02:39
Default Hi, On a similar note, if I
rswbroers
On a similar note, if I were to simulate boundary layer suction or blowing, would it be valid to use an ordinary wall boundary condition with a (strictly) normal velocity specified (either by using fixedValue or surfaceNormalFixedValue), or would a specialized boundary condition need to be build?
Also, could, for moderate normal velocities, a wall function still be used? Or will a low-Re turbulence model be required?
best regards,
Roland
Old   July 3, 2007, 08:16
Default Hi Alberto, thanks for the
Fabian Braennstroem
Hi Alberto,
thanks for the help!
Regards!
Fabian
WALL normal velocity Luca Main CFD Forum 1 October 8, 2014 05:21
Opening BC: Normal to boundary Jan Ramboer CFX 3 September 21, 2007 15:06
velocity normal to the surface srinivas Siemens 1 May 30, 2007 02:03
Velocity gradient normal to a wall ap FLUENT 0 July 26, 2004 08:32
Shear and normal stress on a boundary Fing CFX 2 May 27, 2004 01:47
