Velocity profile
Old   March 29, 2006, 06:30
Default Is it possible with these line
  #21
Anja Stretz
anja is on a distinguished road
Is it possible with these lines:
scalar dx = x - Cp*vector(1,0,0);
scalar dy = y - Cp*vector(0,1,0);
scalar dz = z - Cp*vector(0,0,1);
scalar d = sqrt(dx*dx+dy*dy+dz*dz);
to find the distance of each each cell to the centre of the inlet?
Or is this basically not the way to do that?
Thanks
Anja
anja is offline   Reply With Quote
Old   March 29, 2006, 06:50
Default There is almost always a bette
  #22
Eugene de Villiers
eugene is on a distinguished road
There is almost always a better way to do things in OF.
scalarField d = mag(mesh.C() - Cp);
eugene is offline   Reply With Quote
Old   March 30, 2006, 06:16
Default Hi, Thanks, it seems to wor
  #23
Anja Stretz
Thanks, it seems to work, or at least there was no error reported while compiling.
The problem is that I can't use my application yet. When I try the way Fabian was describing:
Usage: ssimpleFoam <root> <case> [-parallel]
ERROR: wrong number of arguments, expected 2 found 3
So what do I have to do that I can use my velocity profil for an inlet?
Thanks
Anja
Old   December 21, 2006, 10:29
Default Hi fabian when i used your
  #24
morteza mirsaeedi
mirsaeedi is on a distinguished road
Hi fabian
when i used your ssimpleFoam and wmake it i recieved below error:
Foam::error::printStack(Foam:stream&)
Foam::error::abort()
Foam::operator+(Foam::dimensionSet const&, Foam::dimensionSet const&)
Foam::tmp<foam::geometricfield<double,> > Foam::operator+<double,>(Foam::tmp<foam::geometric field<double,> > const&, Foam::tmp<foam::geometricfield<double,> > const&)
mySpecialFoam [0x80c551b]
mySpecialFoam [0x805b769]
__libc_start_main
__gxx_personality_v0
Aborted
i think it is from line " scalarField y=centre.component(vector::Y);"
Do you have any suggestion?
Thanx
Misaeedi.
mirsaeedi is offline   Reply With Quote
Old   December 21, 2006, 10:43
Default I have another question? I
  #25
morteza mirsaeedi
I can not register in workshop of openfoam and i am new with openfoam and c++.
My MSC thesis is about solving Supercavitation phenomena with LES method.
is openFoam an apropriate tool to do this thesis?if it is, can i learn openfoam and it's programming on myself. ofcourse i have read the Userguide and programmer's Guide but i think it is not suffiecient for me and my thesis.
thanks
Morteza
Old   May 6, 2010, 08:31
Default Velocity inlet profile
  #26
Aldo Iannetti
aldo.iannetti is on a distinguished road
Hi
I need to use (in my OF 1.6) a velocity profile coming from an external file (reading and interpolate points)
Is there a tool already implemented in my version?
(I'm a new user)
Thanks
Originally Posted by francois View Post
Thank you Hrvoje for this precision !
I will try to make a utility that reads a file with an inlet velocity profile in it and interpolate it on the mesh.
In your previous mail you mentioned a class that can do interpolation for profiles:
src/sampling/interpolateXY/interpolateXY.H
I will try to use it for my utility.
Thank's for taking some of your time to answer questions from newbies !
Francois
aldo.iannetti is offline   Reply With Quote
Old   May 11, 2010, 11:09
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Originally Posted by aldo.iannetti View Post
Hi
(I'm a new user)
Thanks
Hello Aldo and welcome!
Search for the timeVaryingMappedFixedValue boundary condition, it can do what you are looking for.
Enjoy,
mad
maddalena is offline   Reply With Quote
Old   May 11, 2010, 12:04
Aldo Iannetti
Hi Mad and thanks,
Correct me if I'm wrong,timeVaryingMappedFixedValue is for transient bc, I need a spatial varing bc in a way that depends on a spatial interpolation of a number of points given by the user trough an external .dat file.
Do you mean I can use timeVaryingMappedFixedValue modifying it? How?
Aldo
Enjoy,
mad
Old   May 11, 2010, 15:38
maddalena's Avatar
maddalena
Well,
you can use timeVaryingMappedFixedValue with only one sample time, thus it is not time varying! What I usually do is sample data from a OF converged case on an OF format file, adjust their position manually and apply timeVaryingMappedFixedValue bc for velocity in a different case (a subcase). However, I guess it can be used with tests sample data in the same way...
Hope it helps,
cheers,
mad
Old   September 7, 2010, 21:04
Question
  #30
maysmech's Avatar
maysmech is on a distinguished road
Dear Foamers,
I need to define Driver and Seegmiller velocity inlet profile for backward facing step.
How can i write it in 0/U flie?
maysmech is offline   Reply With Quote
Old   April 5, 2011, 13:47
Default use results from old case
  #31
yu
xiyuqiu is on a distinguished road
Hello, is it possible to generate a velocity profile by simply running a development flow case and use the result for the new case's initial condition?
xiyuqiu is offline   Reply With Quote
Old   April 6, 2011, 02:56
maddalena's Avatar
maddalena
Of course it is!
mad
Velocity profile John CFX 0 October 14, 2008 06:47
Velocity profile as an velocity intlet condition kees FLUENT 3 April 16, 2008 18:35
velocity profile as an velocity inlet condition KEES Main CFD Forum 0 April 15, 2008 11:26
velocity profile nabeel FLUENT 0 June 27, 2006 05:32
particle velocity and velocity profile HGG FLUENT 2 June 10, 2001 16:32
