Trouble in starting FoamX
Old   June 28, 2005, 06:12
Default I have encountered the same tr
Jun Ishimoto
ishimotoj is on a distinguished road
I have encountered the same trouble:
By Mr. Carlos H. Galindo-Lopez on Tuesday, April 05, 2005 - 01:10 pm: in starting FoamX.
I have tried,
1. Checking old Foam2.x process running. (There are no old processes)
2. Remove.../apps/FoamX/ns*.ref (at echo $FOAMX_USER_CONFIG)
3. Confirming write permission for the $FOAMX_USER_CONFIG directory.
4. Copy the .OpenFOAM-1.1 to my home directory
5. Re-installed the OpenFOAM 1.1
However the condition has not changed.
Please inform me how to start FoamX correctly.
The error message is as follows:
$ runFoamXHB
Starting NameServer with inet:injector:1234 ...
uncaught MICO exception: IDL:omg.org/CORBA/INITIALIZE:1.0 (0, not-completed)
/home/jun/OpenFOAM/OpenFOAM-1.1/bin/runFoamXHB: line 127: 15884 Aborted nsd -ORBIIOPAddr $myIOP --ior $FOAMX_USER_CONFIG/ns.ref </dev/null
runFoamXHB : cleanup
runFoamXHB: Name server is not running.
[jun@injector FoamX]$ runFoamX
ls: /home/jun/OpenFOAM/jobControl/runningJobs: No such file or directory
ls: /home/jun/OpenFOAM/jobControl/finishedJobs: No such file or directory
Jobs overview (from $FOAM_JOB_DIR):
Running : 0
Finished : 0
Some of the jobs reported as running might actually no longer be running.
You can these remove old jobInfo using the FoamX ProcessEditor or with the
foamCheckJobs script.
/home/jun/OpenFOAM/OpenFOAM-1.1/bin/runFoamXHB: line 127: 15992 Aborted nsd -ORBIIOPAddr $myIOP --ior $FOAMX_USER_CONFIG/ns.ref </dev/null
$ runFoamXHB
ishimotoj is offline   Reply With Quote
Old   June 28, 2005, 10:41
Default This trouble was caused by the
Jun Ishimoto
This trouble was caused by the changing of the network configuration.
Thanks.
Old   July 19, 2005, 01:40
Default but how to resolve it
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
ztdep is offline   Reply With Quote
Old   March 28, 2006, 05:25
Default I have a same problem.. runFo
Navaladi ( navaladi@gmail.com)
navaladi is on a distinguished road
How to resove it..
navaladi is offline   Reply With Quote
Old   November 7, 2006, 08:45
Default Hej, I have a same problem, h
mss
Hej,
I have a same problem, how to solve this?
thanks,
Rita
Starting FoamX error jaswi OpenFOAM Installation 15 February 7, 2012 14:53
Problem Starting FoamX kumar2 OpenFOAM Installation 1 January 9, 2008 09:14
Starting FoamX on SUSE 102 nick23369 OpenFOAM Pre-Processing 0 May 18, 2007 05:56
Problem Starting FoamX kumar2 OpenFOAM Installation 1 February 2, 2006 14:08
level set-starting trouble level set rookie Main CFD Forum 1 October 7, 2004 15:04
