Driver region for LES
Old   June 3, 2009, 05:51
Default Driver region for LES
Prapanch Nair
prapanj is on a distinguished road
I would like to run a LES case(external flow) with a turbulence upstream. In order to create turbulence upstream, I thought I will build a driver region. that has the same cross section as my domain and same number of cell faces as my domains inlet. In this driver region I think of using standard K epsilon. The idea is to have a uniform flow at the inlet and then map the outlet to the inlet so as to make it a periodic(cyclic) flow. How can I do this?
Will the initial boundary condition at the inlet remain, not letting my cyclic condition influence it?
thank you
Prapanj
prapanj is offline   Reply With Quote
Old   June 30, 2009, 13:28
Cedric DUPRAT
cedric_duprat is on a distinguished road
Originally Posted by prapanj View Post
thank you
Prapanj
Hi Prapanj
Maybe you can first have a look on the boundary condition called directMappedPatch
check in the forum you'll find tutorial and details on this BC.
Then, if you want to simulate a LES case, running a cyclic RANS geometry is not enough (of course). You will have to add specific noise, fluctuations at your average parameter.
Otherwise, you can run a previous cyclic LES calculation there, there is no need to add fluctuations but you can get problem to match your mean flow.
Well in fact, the methods depend of your case.
I hope it will help
Cedric
cedric_duprat is offline   Reply With Quote
cyclic, driver, les, periodic
reconstructpar -region borrbyper OpenFOAM Bugs 2 April 23, 2009 13:52
Gambit HEX core method gives unwanted 2D region KK FLUENT 1 February 4, 2008 09:31
Rotating region of a centr. pump - Counter R wall Emre CFX 0 September 20, 2007 09:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
