Mixed BC - heat transfer - laplacianFoam
Like Tree60Likes
Old   May 12, 2011, 05:39
Default What is valueExpression?
  #21
Grim
Opxah is on a distinguished road
Can someone explain what the line valueExpression "Tinf"; does?
I see it used repeatedly, such as in the example below, but don't understand what it's for.
Originally Posted by herbert View Post
rightWall
    type                   groovyBC;
    variables              "htot=1000.0;Tinf=20.0;rho=800.0;cp=385.0;k=DT*rho*cp;";
    fractionExpression  "1.0/(1.0 + k/(mag(delta())*htot))";
Opxah is offline   Reply With Quote
Old   May 12, 2011, 05:51
Raimonds Vilums
argonaut is on a distinguished road
Tinf stand for T_infinity. This notation is quite often used for room or ambient temperature
argonaut is offline   Reply With Quote
Old   May 12, 2011, 06:10
Grim
Why are both valueExpression and fractionExpression used? Could valueExpression be left out?
Also, there seems to be a need for a Neumann condition, why is there no gradientExpression? I'm confused as to how fractionExpression works in combination with valueExpression.
Old   May 12, 2011, 10:17
Brent Craven
brent_craven is on a distinguished road
It is somewhat explained here:
http://www.cfd-online.com/Forums/ope...tml#post295694
brent_craven is offline   Reply With Quote
Old   May 12, 2011, 11:37
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
To implement 2nd order on the boundary you need bigger stencil to be used. To get this you need a fictitious cell from "outside", while for the unstructured grid it is not possible to understand which neighbor is correct from the side of the internal field.
Mixed BC can not treat this equation at the boundary, because you cannot include variable delta vectors in your settings (as well as "k" and "h" can be variable).
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   May 29, 2011, 04:32
Fabian Braennstroem
braennstroem is on a distinguished road
Hello to all,
I have some questions as well...
The explanation of Raimonds was quite interesting, but what I do not understand is where the outer heat transfer coefficient and wall heat conductivity and thickness come into the formula? Or better, how can I remove the calculated inner heat transfer coefficient from the total heat transfer coefficient used in the above equation?
I would rather use:
type groovyBC;
value uniform 1;
gradientExpression "gradT";
fractionExpression "0";
variables "Cp=-1006;alphaa=10.0;d=0.1;lambda=1.7;kValue=(1.0/((1.0/(alphaEff*Cp*mag(delta())))+d/lambda+1/alphaa));Tamb=270;heatFlux=kValue*(T-Tamb);gradT=heatFlux/(alphaEff * Cp);"
Would be nice, if you can comment on this!
Fabian
braennstroem is offline   Reply With Quote
Old   May 29, 2011, 04:36
Here this case is for zero-thickness walls. You just balance your heat fluxes from fluid side and wall side.
Best regards,
Old   May 29, 2011, 06:17
Fabian Braennstroem
Hi Alexander,
thanks for the quick response! But how would I set the value for htot? Is there the fluid-side (inner) wall heat transfer coefficient included? Do you think my mentioned groovyBC approach is good for non-zero-thickness walls? Or is it maybe not needed for room walls in HVAC related problems and I just can use the zero-thickness approach!?
Best Regards
Fabian
Old   May 29, 2011, 10:45
Ben K
benk is on a distinguished road
Fabian: Your method is like setting a fixedGradient boundary condition which updates the gradient value after each internal iteration, alternatively you could do the same with a fixedValue boundary condition. This should work, but I believe it will be slower to converge than the other method mentioned in this post which is more implicit.
Read this post: http://www.cfd-online.com/Forums/ope...tml#post268458
benk is offline   Reply With Quote
Old   May 29, 2011, 10:48
Hi Fabian!
Let's clarify the BC which are discussed here:
you have your heat transfer coefficient (HTC) defined for the heat exchange between solid and liquid regions. It is already includes wall thickness, the only thing which is also defined is external temperature. You can suppose that it is you room temperature or cooling system liquid temperature.
It is a kind of the simplified approach: you have HTC parameter coming e.g. from experimental measurements and you neglect (do not model) heat conduction processes through your wall. The liquid flux is also estimated here assuming "laminar" model for turbulent flow: q = lambda_eff * sGrad(T). If you include wall functionsm it becomes more complicate when discretized.
Considering your question: what model and equations do intend to simulate for the wall. It can be:
1) Full 3D conjugated heat transfer task (see some solvers and tutorials in OF).
2) To simplify the calculations you can assume 2D or even 1D wall heat conduction.
Best regards,
Old   May 29, 2011, 14:49
Fabian Braennstroem
Hello to you both,
thanks for the explanation! Though I still have some troubles to really understand :-(
Let's say I would like to model a wall with:
alphaOuter=10W/m2K a assumed (not modelled) thickness of d=0.1m with a heat conduction coefficient lambda=2.3W/mK and an ambient temperature of 273.15K...
What would I need to set for 'htot'? Is it just htot= 1/(d/lambda+1/alphaOuter)?
rightWall
type groovyBC;
variables "htot=1000.0;Tinf=273.15;cp=1006.0;k=alphaEff*cp;" ;
}Thanks for your help!
Fabian
Old   May 30, 2011, 04:57
Raimonds Vilums
Let's get clear with mathematics. The BC, which I implemented, is
k, h, Tinf are known
What is your formula to be implemented?
P.S. I found this useful link to generate image url which displays latex formula
Old   May 31, 2011, 03:12
Fabian Braennstroem
I would say, that I have almost the same, but for h I used:
h=1/(1/alphaInner+d/lambda+1/alphaOuter)
With alphaInner=alphaEff*Cp*mag(delta()))
which is probably not correct to include in h (k-value), as I use the wall temperature (T) and not the fluid temperature.
So it should rather be:
variables "Cp=-1006;alphaa=10.0;d=0.1;lambda=1.7;kValue=(1.0/(d/lambda+1/alphaa));Tamb=270;heatFlux=kValue*(T-Tamb);gradT=heatFlux/(alphaEff * Cp);"
And for the existing wallHeatTransfer alphaWall would be the same as the above kValue. (the missing part for the wallHeatTransfer bc is the use of alphaEff)
Is this correct?
Thanks! Fabian
Old   May 31, 2011, 09:19
Ben K
Fabian: Just out of interest, are you trying to come up with a modified heat transfer coefficient (h) instead of directly modelling the temperature drop through the wall which I'm guessing is like a thin interface?
If so, have you considered making a thermal conductivity field as a function of position where the thermal conductivity changes from one value to another at the inner wall interface? For this, you might also need to refine your mesh a bit around the wall, but then you can just use a normal definition of the heat transfer coefficient.
Old   May 31, 2011, 11:30
Fabian Braennstroem
Hello Ben,
sorry.. I have trouble to follow :-(
I try it in other words, my scenario looks like this:
I have a really simple room with walls (like the hotRoom) tutorial. In addition I have a free cylinder placed in the middle of the room with an heatflux boundary condition. I am running buoyantSimpleFoam. Now I would like to set for the walls a boundary condition for temperature, which adjusts the temperature (or gradient) of these walls, according to a given heat transfer coefficient. In the end of the hotroom and heated cylinder (1000W) I would like set the boundary condition that I will get a kind of mean air temperature of 20 Celsius with an outer ambient temperature of 10 Celsius. This would work out with a total heat transfer coefficient of 1W/m2K when the walls have an total area of 100m2.
Best Regards!
Fabian
Old   January 14, 2012, 13:16
Ehsan
ehsan is on a distinguished road
Hello
I like to imply a simple adiabatic wall B.C for rhoCenteralFoam? Could you please give me a clue?
Thanks
ehsan is offline   Reply With Quote
Old   February 9, 2012, 09:03
paalj is on a distinguished road
Dear All,
I am quite new to OpenFoam and I try to implement heat transfer coefficient in laplacian foam via groovybc. I downloaded and compiled Swak4Foam sucessfully and added following expressions in "0/T":
__________________________________________________ _________
corner_wide_side
type groovyBC;
value uniform 1800;
variables (
"htot = 1200.0;"
"Tinf = 323.15;"
"rho = 7200.0;"
"cp = 700.0;"
"k = 30.0;"
__________________________________________________ __________
I receive the following error message:
Calculating temperature distribution
Time = 0.04
word::stripInvalid() called for word htot
For debug level (= 2) > 1 this is considered fatal
Abgebrochen
Any ideas?
Best regards!
paalj is offline   Reply With Quote
Old   February 9, 2012, 09:30
Well, I think I was able to solve the problem by deleting the spaces - seems to work now.
Best regards
Old   September 20, 2012, 17:59
Default changing refValue
  #39
hawkeye321 is an unknown quantity at this point
Hi
Do you guys have any idea how I can change the value of refValue to some other value than the default 0?
When I am solving the heat transfer problem with convective bc following the discussions above, my final steady temperature is always 0, which seems to be wrong; the temperature should, ultimately, reach the ambient temperature.
hawkeye321 is offline   Reply With Quote
Old   September 20, 2012, 18:05
For convective BC you have to write your own implementation based on mixed type
Best regards,
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
CFX Heat Transfer RJamison CFX 0 July 24, 2008 12:11
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
