Problem compiling custom boundary condition as a library
Like Tree1Likes
  • 1 Post By alexeym
Old   January 21, 2014, 10:12
Post Problem compiling custom boundary condition as a library
Vincent Leroy
leroyv is on a distinguished road
Dear OpenFOAM programmers,
I am learning how to write my own boundary conditions. This BC represents a mass source term at a reacting boundary. The velocity on the patch is non zero, orthogonal to the patch, and depends on the local density of the fluid and solid phase. I designed it after the oscillatingFixedValue and surfaceNormalFixedValue patches. The header and implementation files are attached.
When I try to compile the llibrary using the wmake libso command, wmake and GCC throw the following error messages (we have some French in there, sorry for that):
In file included from pyrolysisVelocityFvPatchField.C:26:0:
pyrolysisVelocityFvPatchField.H:243:1: erreur: ‘patch’ has not been declared
pyrolysisVelocityFvPatchField.H:243:1: erreur: expected constructor, destructor, or type conversion before ‘;’ token
pyrolysisVelocityFvPatchField.H:243:1: erreur: ‘patchMapper’ has not been declared
make: *** [Make/linux64GccDPOpt/pyrolysisVelocityFvPatchField.o] Erreur 1
Line 243 of pyrolysisVelocityFvPatchField.H is where we find the makePatchField macro. I double checked with other non templated BCs using this macro, and it seems to me like I'm using it correctly. I honestly don't have an idea of what is missing there, does anyone know what is wrong with my code? Any missing constructors or something? I had to remove a few things when I wrote the code, like the mapper methods; are they required?
Vincent
leroyv is offline   Reply With Quote
Old   January 21, 2014, 10:39
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
It seems that you forgot
#include "addToRunTimeSelectionTable.H"
And AFAIR usually makePatchTypeFIield macro is in implementation file (C).
leroyv likes this.
alexeym is offline   Reply With Quote
Old   January 21, 2014, 10:44
Smile Solved
Vincent Leroy
Originally Posted by alexeym View Post
Dear Alexey,
Thank you for your answer, it solved the compilation errors.
boundary condition, library, openfoam, patch
problem about pressure boundary condition at sharp corner yhaomin2007 OpenFOAM Running, Solving & CFD 1 January 19, 2016 09:24
Radiation interface hinca CFX 15 January 26, 2014 17:11
Pressure Boundary Condition Problem rbjet CFX 3 July 15, 2013 21:45
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
a problem with Boundary condition M Rad Main CFD Forum 12 November 27, 1998 12:49
