gradientInternalCoeffs cannot be called for a calculatedFvPatchField
Like Tree7Likes
Old   September 28, 2012, 05:27
Default gradientInternalCoeffs cannot be called for a calculatedFvPatchField
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
hi everybody,
I defined a new solver that solve natural convection in a viscoelastic Fluid. it made successfully, but when I want to run my model the following error was appeared:
--> FOAM FATAL ERROR:
     on patch floor of field p in file "/home/mostafa/OpenFOAM/mostafa-2.1.0/run/tutorials/viscoelastic/viscoelasticFluidFoam/Hasan_Giesekus/0/p"
     You are probably trying to solve for a field with a default boundary condition.
     From function calculatedFvPatchField<Type>::gradientInternalCoeffs() const
     in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 186.
  FOAM exiting
do anybody know where is the problem?
Thanks
Kummi likes this.
adambarfi is offline   Reply With Quote
Old   September 28, 2012, 15:01
Nima Samkhaniani
nimasam is on a distinguished road
DEAR mostafa
could you post your p file here?
nimasam is offline   Reply With Quote
Old   September 28, 2012, 16:08
adambarfi's Avatar
Mostafa Mahmoudi
the attachment contains the p, fvSolution and fvSchemes files.
I changed the floor boundary condition and even delete the p file but this problem didn't had been solve. I think the problem is somewhere in the fvSolution or fvSchemes.
Old   September 28, 2012, 17:37
Nima Samkhaniani
this solver reads p or p-rgh ?
it seems it reads p, if it reads p! then you should define BC for p, you can not use calculated BC, you should use (fixedValue or fixedGradient) for it
vs1 and Teresa Sun like this.
Old   September 28, 2012, 23:36
adambarfi's Avatar
Mostafa Mahmoudi
It reads p and calculate the p-rgh, such as bouyantbuossinesqsimplefoam. I change the bc to fixedValue and fixedGradient but this this error didn't had been omit.
Old   September 29, 2012, 02:57
Nima Samkhaniani
Dear mostafa let me ask another questions, which version of openfoam do you use?
could you run this test case before heat transfer implementation?
put the test case and solver here, then may other can help you
Old   September 29, 2012, 05:42
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi
Did you set p equal to another field in your solver during calculations? i.g.
p=....?
ata is offline   Reply With Quote
Old   September 29, 2012, 06:09
adambarfi's Avatar
Mostafa Mahmoudi
this is where I use the p in createFields.H:
    Info<< "Calculating field g.h\n" << endl;
    volScalarField gh("gh", g & mesh.C());
    surfaceScalarField ghf("ghf", g & mesh.Cf());
    volScalarField p
        IOobject
            "p",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        p_rgh + rhok*gh
    label pRefCell = 0;
    scalar pRefValue = 0.0;
    setRefCell(p,p_rgh, mesh.solutionDict().subDict("PISO"), pRefCell, pRefValue);
    if (p_rgh.needReference())
        p += dimensionedScalar
            "p",
            p.dimensions(),
            pRefValue - getRefCellValue(p, pRefCell)
and in pEqn:
    p = p_rgh + rhok*gh;
            "p",
            p.dimensions(),
        p_rgh = p - rhok*gh;
what is wrong in my code?
Old   September 29, 2012, 06:33
ata
ata's Avatar
ata kamyabi
Hi
I think you have two options two solve the problem. Selection is your choice:
1:
volScalarField p ( IOobject ( "p", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh );
or
2:
p == p_rgh + rhok*gh;
Teresa Sun likes this.
Old   September 29, 2012, 07:21
adambarfi's Avatar
Mostafa Mahmoudi
Dear Ata
I applied what you offered me and what Nima said, that error was solved. but after some iterations (50) the following error appeared:
#0  Foam::error::printStack(Foam::Ostream&) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4  Foam::fvMatrix<Foam::SymmTensor<double> >::solve(Foam::dictionary const&) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#5  Foam::fvMatrix<Foam::SymmTensor<double> >::solve() in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#6  Foam::Giesekus::correct() in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#7  Foam::multiMode::correct() in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#8  Foam::viscoelasticModel::correct() in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
 in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/BuoyantBoussinesqViscoelasticFluidFoam"
#10  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#11
Floating point exception
what is your opinion about this error?
again thank you so much
Old   September 29, 2012, 15:21
Nima Samkhaniani
it seems somewhere in your code something divide on zero or going to result indefinite value
Old   February 23, 2013, 01:34
Default Dear adambarfi,
  #12
T. Chourushi
Tushar@cfd is on a distinguished road
Are you able to resolve your error?
Tushar@cfd is offline   Reply With Quote
Old   February 23, 2013, 01:44
adambarfi's Avatar
Mostafa Mahmoudi
Dear Tushar,
yes, after some day hard working, finally I could solve it.
Old   November 11, 2013, 02:06
sasan
Sasy is on a distinguished road
Originally Posted by adambarfi View Post
Dear Tushar,
Dear Mostafa
how do you solved this problem?? I have some problem like this,but my problem dont solve by ata or nima offers...
I use interPhasechangeFoam solver and modified this solver for my simulation...
you can see my creatFields and Peqn
Sasy is offline   Reply With Quote
Old   November 12, 2013, 00:46
adambarfi's Avatar
Mostafa Mahmoudi
hi Sasan,
I get your attached files and I couldn't find any thing that made error!
so, attach your log file + the errors expression
Old   November 12, 2013, 03:18
sasan
hi Sasan,
Hi Mostafa
Thank you for reply..
my error:
FOAM FATAL ERROR:
on patch left of field p in file "/home/Sasan/Desktop/HardtMix/stephanProblem/0/p"
and attach the log file
Old   November 12, 2013, 07:10
adambarfi's Avatar
Mostafa Mahmoudi
You have to specify correct boundary conditions for p otherwise you cannot solve the pEqn!
The error message gave you already a hint what you have to do:
so, you are using a wrong BC for pEqn. I guess you used calculated type!
try other boundary conditions that are compatible with your solution.
vs1 likes this.
Old   November 13, 2013, 02:03
sasan
Hi Mostafa
I used this test case with another solver and dont have problem,But for new solver,I have this problem.
my BC is not calculated....!!
you can see:
Old   November 13, 2013, 02:04
sasan
Originally Posted by Sasy View Post
Hi Mostafa
you can see:
sorry.I forgot attach my file...
Old   November 13, 2013, 03:07
adambarfi's Avatar
Mostafa Mahmoudi
mhmm, I think there are problems with p BCs.
the userGuide says:
At all wall boundaries, the buoyantPressure boundary condition is applied to the pressure
field, which calculates the normal gradient from the local density gradient.
buoyantPressure: Sets fixedGradient pressure based on the atmospheric pressure gradient
I think such same BCs for p and p_rgh is wrong, let the solver calculate the pressure based upon potential function. try "calculated" type for p BCs.
Also, I can't understand these conditions you used for p_rgh:
        type            buoyantPressure;
        gradient        uniform 0;
        value           uniform 0;
try this one:
        rho             rhok;
        value           uniform 0;
see the buoyantBoussinesqPimpleFoam and buoyantBoussinesqSimpleFoam solvers. they have tips that may help you.
How is the turbulence model called in openfoam? hz283 OpenFOAM 3 May 4, 2017 21:20
terminate called after throwing an instance of 'int' b614910 SU2 10 July 27, 2014 22:16
word::stripInvalid() called for word r error immortality OpenFOAM Running, Solving & CFD 4 May 12, 2013 06:03
understanding how turbulence models are called romant OpenFOAM Programming & Development 0 March 21, 2012 09:22
reconstructParMesh not working with an axisymetric case francesco OpenFOAM Bugs 4 May 8, 2009 05:49
