Face weighted Velocity average at a boundary patch
Like Tree7Likes
  • 1 Post By wyldckat
  • 1 Post By luhawk
  • 5 Post By wyldckat
Old   October 18, 2012, 05:33
Default Face weighted Velocity average at a boundary patch
Lukas
luhawk is on a distinguished road
Hi everybody,
I am currently trying to implement the calculation of a cell face weighted Velocity average in flow direction as a dimensioned scalar. The cell face for weighting shall be the one at the defined boundary patch.
I tried:
dimensionedScalar weightedVelocity = (flowDirection & U)().weightedAverage(mesh.boundary()[patchID].Sf());
but the prompt (as I interpret it) says that weightedAverage will only accept a volume Mesh field not a field:
error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::weightedAverage(const Foam::Field<Foam::Vector<double> >&)’
/opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/DimensionedField.C:381: note: candidates are: Foam::dimensioned<Type> Foam::DimensionedField<Type, GeoMesh>::weightedAverage(const Foam::DimensionedField<double, GeoMesh>&) const [with Type = double, GeoMesh = Foam::volMesh]
/opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/DimensionedField.C:399: note:                 Foam::dimensioned<Type> Foam::DimensionedField<Type, GeoMesh>::weightedAverage(const Foam::tmp<Foam::DimensionedField<double, GeoMesh> >&) const [with Type = double, GeoMesh = Foam::volMesh]
so I tried using fvc::average as follows:
dimensionedScalar weightedVelocity = average(flowDirection & U.boundaryField()[patchID]);
It compiles but when i run the code i get the dimension error:
--> FOAM FATAL ERROR:
LHS and RHS of - have different dimensions
     dimensions : [0 1 -1 0 0 0 0] - [0 0 0 0 0 0 0]
where weightedVelocity is the RHS. So my question is why do i loose the dimension when averaging or are there any other ideas to get the weighted average?
Thanks for your answers,
Cheers Lu
luhawk is offline   Reply With Quote
Old   October 19, 2012, 15:44
Retired Super Moderator
Bruno Santos
Greetings Lukas,
I did a quick search on this subject and found this thread: http://www.cfd-online.com/Forums/ope...onditions.html
From it you'll see that they mention patchAverage. The source code for this application is located here: "applications/utilities/postProcessing/patch/patchAverage/patchAverage.C"
If I'm not mistaken, this code uses area weighted average on patches.
If you need to integrate, looks like patchAverage has a sibling named patchIntegrate
Best regards,
Bruno
Hamoon likes this.
Old   October 25, 2012, 04:06
Lukas
Hi Bruno,
thanks for your answer, I also stumbled upon this thread during my search for a solution. The problem is that I want to integrate the calculation into my solver and use the average value as a corrector. As far as I can see this is just for post processing. But I'll have a closer look at patchAverage, maybe it'll help. I'll post the solution when I found it.
Cheers Luk
Old   October 25, 2012, 11:20
Lukas
Hello again Bruno,
hello everybody,
I worked something out now but only for serial computation. In parallel it does not work because the area of the patch on which I want to average is not calculated properly.
My code for that is:
                label PatchID = mesh.boundaryMesh().findPatchID(patchName);
                scalar area = gSum(mesh.magSf().boundaryField()[PatchID]);
                reduce(area, sumOp<scalar>() );
                Info<< "area: "<< area<< endl;
As I said it works neatly for serial computation and the prompt returns the right area (some hundret square millimeters). For parallel computation the prompt gives 0 which then leads to the crash of my computation since I devide by "area" later. Is the reduce command not the right thing to do? Fyi the patch on which I do the computation is a cyclic BC if this has anything to do with it.
I appreciate your help,
Luk
/edit:
Now I added an output to see what the areas of the surface on the different processors are: It gives:
[3] area_proc: 0
[4] area_proc: 0
[5] area_proc: 0
[6] area_proc: 0
[7] area_proc: 0
[8] area_proc: 0
[9] area_proc: 0
[10] area_proc: 0
[11] area_proc: 0
[12] area_proc: 0
[13] area_proc: 0
[14] area_proc: 0
[15] area_proc: 0
[0] area_proc: 0
area: 0
[1] area_proc: 0
[2] area_proc: 0
Since I used simple decomposition (amon others) this is definitely not true for processor 0 since the patch is only located there. Any clues why this does not work? Thanks!
mm.abdollahzadeh likes this.
Old   October 26, 2012, 18:05
Bruno Santos
Hi Lukas,
That's strange, the code seems good enough to work in parallel as well.
Have you tried running patchAverage with your case, both in serial and parallel? Because if patchAverage is not working correctly, then the problem could be in OpenFOAM itself!
Best regards,
Bruno
Old   October 27, 2012, 08:52
Lukas
Hi Bruno,
first of all thanks for concerning yourself with my stuff.
I tried to run the patchAverage on my case in parallel. Since I want to run in on the x-Component of the velocity in my solver I first did the foamCalc operation:
lukas@cluster:/scratch/luk/testcase$ mpirun -np 16 foamCalc components U -parallel
Selecting calcType components
Pstream initialized with:
    floatTransfer     : 0
    nProcsSimpleSum   : 0
    commsType         : nonBlocking
Create time
Create mesh for time = 0
Time = 0
    Reading U
    Calculating Ux
    Calculating Uy
    Calculating Uz
Time = 0.5
    Reading U
    Calculating Ux
    Calculating Uy
    Calculating Uz
Time = 1
    Reading U
    Calculating Ux
    Calculating Uy
    Calculating Uz
Time = 15
    Reading U
    Calculating Ux
    Calculating Uy
    Calculating Uz
End
Finalising parallel run
So this seems to have worked the Ux files are filled with values. The I ran the patchAverage tool on the Ux field which yields in the following output:
lukas@cluster:/scratch/luk/testcase$ mpirun -np 16 patchAverage Ux INLET -parallel
Create time
Time = 0
    Reading volScalarField Ux
    Average of Ux over patch INLET[5] = 0
Time = 0.5
Time = 1
Time = 1.5
Time = 14.5
Time = 15
End
So this seems like the patchAverage program itself is not perallelized correctly. To exclude foamCalc as an error source (which is rather unlikely since the Ux files in the processor time directories are fille with values) I also ran patchAverage on the pressure. This also gives an average of 0 which confirms this conclusion.
Up to now I'm a bit clueless on the reason but I'll try the patchAverage on the pitzDaily tutorial later in paralell to verify that the problem is not in my case.
So long, best regards,
Lukas
Old   October 27, 2012, 12:39
Bruno Santos
Hi Lukas,
Which OpenFOAM version are you using?
I've used both OpenFOAM 2.1.1 and 2.1.x, did a quick test with the tutorial "multiphase/interFoam/laminar/damBreak" in both serial and parallel with these commands:
blockMesh
cp 0/alpha1.org 0/alpha1
setFields
#for parallel mode
decomposePar
foamJob -p -s interFoam
foamJob -s -p patchAverage alpha1 lowerWall
#for serial mode
interFoam
And both worked without any problems!
I haven't tried on a cyclic patch yet... I'll have to find a tutorial first... I'll edit this post if and when I find one and test it.
edit: I've tested with the tutorial "incompressible/pimpleFoam/TJunctionFan", by modifying the last line in Allrun from this:
runApplication $application
To this:
runApplication decomposePar
runParallel $application 4
mv log.$application log.$application.parallel
Copied the decomposition dictionary from the other tutorial:
cp $FOAM_TUTORIALS/multiphase/interFoam/laminar/damBreak/system/decompo* system/
Then ran:
./Allrun
and then patchAverage in both modes:
patchAverage p fan_half0
# visually check the last couple of values then run in parallel
foamJob -p -s patchAverage p fan_half0
The values were a bit different, but not null! And "fan_half0" is a cyclic patch!
edit2: The other corresponding cyclic patch "fan_half1" gave veeeery different values, by about an order of magnitude of 10x! For comparison, at time = 1.5s and "p" field:
  • fan_half1 parallel: 30.055
  • fan_half1 serial: 25.9596
  • fan_half0 serial: -73.0923
  • fan_half0 parallel: -69.0298
Since it's a motor fan, it makes sense that one one side has negative pressure and positive on the other side. Nonetheless, there is a substantial difference in values between serial and parallel.
I'm going to test with scotch decomposition instead of simple, because the cyclic patch was split between 2 processor sub-domains...
edit3: With scotch decomposition the patch wasn't split:
  • fan_half1 parallel: 26.1313
  • fan_half0 parallel: -72.9261
OK, this is a lot better. It does seem that patchAverage can't handle very well patches that cross over processor boundaries.
Best regards,
Bruno
Last edited by wyldckat; October 27, 2012 at 14:58. Reason: see "edit:", "edit2:" and "edit3:"
Old   November 7, 2012, 10:13
Lukas
Hi Bruno,
hi all.
first of all thank you Bruno for your help, your last sentence gave the hint on the actual bug which is in both my code and the patchAverage tool. I used OFv 2.1.0 for all the previous and following stuff.
I ran the tutorials you gave and got the same results, but what lightened me up was the channel395 tutorial which works with channelFoam. When a cyclic case is decomposed the and the processor boundary is at the cyclic patch the patch is reassigned from e.g. "INLET" to "processorXtoprocessorYthroughINLET". The "INLET" patch however will still be present in the files. This yields that
where patchName is "INLET" does return an ID but this ID is no longer correspondant to the patch "processorXtoprocessorYthroughINLET". If parts of the "INLET" patch are not covered by an inter-processor boundary patchAverage will still give results, but wrong ones. If all of the "INLET" patch is inter-processor boundaries the area of "INLET" will be zero since all of inlet is covered by one or several "processorXtoprocessorYthroughINLET" processorCyclic patches and patchAverage will simply return 0.
Well that is that. Since I still want my solver to work I now need the patch ID's of all patches which involve the string stored in patchName in their name. Is there something like a wildcard in openFoam like findPatchID(.*patchName) (seen it the BCs of the motorbike tutorial)? (This does not work, I already tried it ). Since the class for one single patchID was label I tried to extract the patchIDs of all patches which contain the string stored in patchName as a labelList as follows:
        labelList UbarPatches;
        scalar count = 0;
        UbarPatches[count] = -1;
        const fvPatchList& patches = mesh.boundary();
        forAll(patches, patchI)
                if (patches[patchI].name() == ".*patchName")
                        UbarPatches[count] = patchI;
                        count += 1;
This compiles but gives a SegFault when ran. Does anybody have an Idea how to extract a list of the IDs of the patch named "somethingsomethingpatchName" this would be very helpful.
Thanks in advance, your help is appreciated!
Best regards, Luk
Old   November 9, 2012, 17:56
Bruno Santos
Hi Lukas,
There is a somewhat easier way to take care of this. Using as a reference the previous example tutorial:
  1. Edit the file "system/decomposeParDict".
  2. Add this line:
    preservePatches (fan_half0 fan_half1);
  3. Now decompose the case and run the solver!
That line in the dictionary does what it says: preserves the patches in a single processor!
Best regards,
Bruno
fumiya, luhawk, utkunun and 2 others like this.
Old   November 11, 2012, 08:38
Lukas
Works perfectly fine. Thank you very much!
Old   May 13, 2013, 21:53
pooyan
sam1364 is on a distinguished road
Hey guys,
I am trying to calculate the patch average value of phi (or mass flux) when running in parallel. I have written the code below which works well for serial computation. is there any suggestion how to make it work for parallel computation?
word inletPatchName = "inflow_cyclic";
//access boundary elements
//loop over boundaries
const fvPatch& cPatch = patches[patchI];
//check boundary name
if(cPatch.name() == inletPatchName)
//loop over all faces of selected
//boundary
forAll(cPatch, faceI)
//calculate boundary face mass flux
dimensionedScalar cFaceFlux
= phi.boundaryField()[patchI][faceI]*magUbar;
//sum face mass fluxes
massFluxInlet += mag(cFaceFlux);
sam1364 is offline   Reply With Quote
Old   May 14, 2013, 05:25
Lukas
Hi pooyan,
Which decomposition method do you use? Have you used the preservePatches option for your cyclic patches?
Best regards,
Lukas
Old   May 14, 2013, 09:07
pooyan
I have used simple method. And have included preservePatches(cyclic boundaries) in the decomposeParDict. Even when I use simple method and use (4 1 1), I expect that the decomposition is made in x direction, so only one processor is working on my inflow_cyclic and therfore It should be able to calculate the right flux. Any suggestion?
Thanks
Old   May 22, 2013, 10:16
Lukas
Hi pooyan,
sorry for replying late but i was out of office for a few days. Actually I have no idea why it does work in serial but not in parallel. But I think I have a general problem with understanding your calculation. You want to calculate the "average value of the flux over your inlet patch" is this correct?
Your computation:
First of all, why do you multiply with magUbar? Phi is already a flux with [m^3/s], isn't it? If you multiply it with a velocity (magUbar) you should get something with [m^4/s^2] which is no flux.
You could do an averaging with the number of faces considered. But imo you should calculate a flux average weighted with they area of the considered faces. Something like
scalar area = gSum(mesh.magSf().boundaryField()[patchI); // Total area of your boundary Patch
dimensionedScalar faceWeightedFlux
       "faceWeightedFlux",
       dimensionSet(0,3,-1,0,0,0,0),
       gSum(mesh.magSf().boundaryField()[patchI] * phi.boundaryField([patchI]) /area
COULD do the work (no guarantee, did not try it). If I have not understood your issue pls excuse.
Regards Luk
[Commercial meshers] Fluent msh and cyclic boundary cfdengineering OpenFOAM Meshing & Mesh Conversion 48 January 25, 2013 03:28
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
[mesh manipulation] Using createPatch in place of couplePatches sripplinger OpenFOAM Meshing & Mesh Conversion 8 November 13, 2009 07:14
