December 4, 2012, 06:16 |
word::stripInvalid() called for word r
Ehsan
Rep Power: 26 |
whats the cause of this error?
Starting time loop Mean and max Courant Numbers = 0.106808 0.225305 deltaT = 1.11111e-07 Time = 1.11111e-07 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 swak4Foam: Allocating new repository for sampledGlobalVariables smoothSolver: Solving for Ux, Initial residual = 0.00493778, Final residual = 1.54499e-17, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 9.94124e-17, No Iterations 3 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 word::stripInvalid() called for word r For debug level (= 2) > 1 this is considered fatal Aborted |
December 18, 2012, 08:49 |
Joe Nick
Rep Power: 13 |
a Foam::word may not contain spaces and a few other characters. Use a debugger or add several printf statements to your solver to find the location which causes the error and make sure to use only valid characters. |
December 26, 2012, 04:26 |
#3 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
How is the turbulence model called in openfoam? | hz283 | OpenFOAM | 3 | May 4, 2017 21:20 |
word::stripInvalid() called for word r error | immortality | OpenFOAM Running, Solving & CFD | 4 | May 12, 2013 06:03 |
whats the error? word::stripInvalid() called for word r | immortality | OpenFOAM Running, Solving & CFD | 0 | December 3, 2012 17:55 |
understanding how turbulence models are called | romant | OpenFOAM Programming & Development | 0 | March 21, 2012 09:22 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 05:49 |
