January 29, 2013, 14:07 |
Questions on H2O.H
Christopher Hughes
Rep Power: 13 |
I'm interested in using the H2O.H thermo model with the chtMultiRegionFoam solver to better model compressible water in a conjugate heat transfer system.
The current chtMultiRegionFoam setup of the thermoproperties as: thermoType hRhoThermo<pureMixture<constTransport<specieThermo <hConstThermo<incompressible>>>>>; From the user guide I understand it is describing the thermoModel<mixturemodel<transportmodel<speciemode l<propertymodel<compressibility> but that is the syntax for hRhoThermo. Since I want to use water and not a gas, what is the proper syntax to call and use H2O.H since it describes all the properties of water based solely on T, P? I also know that the chtMultiRegionFoam and all the fluid set field files will have to be changed to reflect the change in the thermoModel so any insight into proper syntax in these files would also be appreciated. |
possible interview questions | atturh | Main CFD Forum | 1 | February 21, 2012 08:53 |
LES basic and simple questions. | dshawul | Main CFD Forum | 0 | October 4, 2010 10:56 |
NACA0012 Validation Case Questions | ozzythewise | Main CFD Forum | 3 | August 3, 2010 14:39 |
novice star ccm+ questions | apc3161 | STAR-CCM+ | 2 | August 25, 2009 10:15 |
Questions about CFD | Lebeau alexandre | Main CFD Forum | 1 | April 6, 1999 14:23 |
