Loop over Points of a boundary / patch
Like Tree3Likes
  • 3 Post By blais.bruno
Old   March 5, 2013, 05:47
Default Loop over Points of a boundary / patch
HECKMANN Frédéric
fredo490 is on a distinguished road
Dear all,
I am looking for a code able to loop over the points of a patch. From my research it seems that there is no member to find the points of a face. How can we get from a known face the corresponding nodes ?
My idea is to get an algorithm like this
- get patch id
- loop over face of the patch
- loop over the points of the faces
-> do a point treatment (an arbitraty movement in my case)
Thx in advance
fredo490 is offline   Reply With Quote
Old   March 5, 2013, 07:49
Default meshPoints() function
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You can use the meshPoints() function.
The following thread will be of help:
http://www.cfd-online.com/Forums/ope...ary-patch.html
Fumiya
fumiya is offline   Reply With Quote
Old   March 7, 2013, 03:19
HECKMANN Frédéric
Your link is quite useful ! It's not perfect but still really good. I guess there is no elegant way to do what I want.
Thx.
Old   May 25, 2015, 04:34
Fei Fan
Fanfei is on a distinguished road
Originally Posted by fredo490 View Post
Dear all,
- get patch id
Thx in advance
Hi fredo:
Have you solve this question now. I have the same problem to access the nodes of face. could you give me a hints. Thanks.
Best regards
Fan Fei
Fanfei is offline   Reply With Quote
Old   July 8, 2015, 10:52
Bruno Blais
blais.bruno is on a distinguished road
Originally Posted by Fanfei View Post
Hi fredo:
Best regards
Fan Fei
There is a good way to loop over a patch.
Here is an example (somebody might correct me, this is not perfect) on how to loop over a boundary patch of which the name is "left". Then you get the position at the center of the face and you apply a function, let's say a cosine in this case.
       label inletPatchID = mesh.boundaryMesh().findPatchID("left"); //Patch identifier of the boundary condition
            fvPatchScalarField& wallP = p.boundaryField()[inletPatchID];  // Obtain a patchScalar field on the BC
	    forAll(wallP, faceI)  // Loop over each face of the patch
		vector pos(mesh.Cf().boundaryField()[inletPatchID][faceI]);
		x = pos[0];
		y = pos[1];
		wallP[faceI]=Foam::cos(PI*x)*Foam::cos(PI*y);;
Cheers
zatralias, Luttappy and erinsam like this.
blais.bruno is offline   Reply With Quote
Old   July 8, 2015, 10:57
Fei Fan
		x = pos[0];
		y = pos[1];
Cheers
Hi
Thanks for you reply me. this problem i have solved. I use lablist to access to the face vertices series number and use mesh.points() to get the coordinate of points.
Best regards
Fan Fei
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) sega OpenFOAM Meshing & Mesh Conversion 3 September 28, 2010 12:46
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
