Problem while getting the initial residual
Like Tree4Likes
  • 4 Post By Orgogozo
Old   August 21, 2012, 10:40
Default Problem while getting the initial residual
Laurent Orgogozo
Orgogozo is on a distinguished road
Dear Foamers,
I am working on a solver (with OF-2.0.1) with an internal correction loop to deal with a non-linear equation.
I try to use the initial residual of the resolution of each iteration of my internal loop to make the exit test of this loop (namely initialResidual<0.1), but :
1) When I use .solve().initialResidual() only, my initial residual is always 1 so that I cannot reach convergence (see Resolutions 1 and 1' and logs 1 or 1' below).
2) When I make successivly a .solve() and a .solve().initialResidual(), everything is fine in transient regime but if a steady state appears, the second resolution implied by .solve().initialResidual() makes the initial residual increasing, and thus impairs convergence (see Resolutions 2 and 2' and logs 2 or 2' below)..
So my question is : in which way can I get acces to the initial residual without make a resolution, or alternatively use only .solve().initialResidual() without fixing the initial residual to one ?
Thank you by advance for your help.
Resolutions 1 and 1':
1 : psiIR=psiEqn.solve().initialResidual();
Info<< "psiIR = " << psiIR << endl;
1': lduMatrix::solverPerformance sp = psiEqn.solve();
psiIR=sp.initialResidual();
logs 1 or 1':
DICPCG: Solving for psi, Initial residual = 1, Final residual = 3.38224e-17, No Iterations 1
psiIR = 1
DICPCG: Solving for psi, Initial residual = 1, Final residual = 1.60809e-19, No Iterations 1
psiIR = 1
DICPCG: Solving for psi, Initial residual = 1, Final residual = 9.66389e-17, No Iterations 1
psiIR = 1
and so on, the initial residual is fixed to one so that the convergence criterium can't be reached.
Resolutions 2 and 2' :
2: psiEqn.solve();
2': psiEqn.solve();
Logs 2 or 2':
before steady state, no problem :
DICPCG: Solving for psi, Initial residual = 0.0582326, Final residual = 4.93904e-20, No Iterations 1
DICPCG: Solving for psi, Initial residual = 3.70557e-16, Final residual = 3.70557e-16, No Iterations 0
psiIR = 3.70557e-16
and that's it, the residual is under the convergence criterium and the computation moves to the next time step.
but as soon as the steady state is reached, the resolution made by the line to get the initial residual (e.g.: psiIR=psiEqn.solve().initialResidual() makes the initial residual increases and thus impairs convergence :
DICPCG: Solving for psi, Initial residual = 0.0436467, Final residual = 2.58946e-15, No Iterations 1
DICPCG: Solving for psi, Initial residual = 0.166518, Final residual = 1.86296e-14, No Iterations 1
psiIR = 0.166518
psiIR = 0.166518
psiIR = 0.166518
and so on, so that the convergence criteria (initial residual less than 0.1 here) can't be reached and the computation diverge.
Yahoo, babala, sima_op and 1 others like this.
Orgogozo is offline   Reply With Quote
Old   March 6, 2013, 12:59
Yahoo is on a distinguished road
Did you figured out how to fix your problem with initial residual?
I am trying to solve equation
fvScalarMatrix CEqn
fvm::ddt(C)
+ fvm::div(phi, C)
CeqnResidual = CEqn.solve().initialResidual();
In case where phi is zero (i.e. no flow), my initial residuals are always high (~ 0.3). When I am forcing the solver to exit without satisfying the convergence criterion (by setting a maximum for the iterations), I see that phi is zero everywhere and C is constant, as I expect. But, I don't know why CeqnResidual is high!
Yahoo is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
icoLagrangianFoam OF1.6 myNewParticleSolver heavy_user OpenFOAM 23 June 2, 2020 02:18
Compressible Nozzle Flow sebastian OpenFOAM Running, Solving & CFD 14 September 21, 2016 10:47
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
