April 4, 2013, 07:12 |
OpenFOAM debugging
klemen
Rep Power: 13 |
I am testing my own simple chtMultiRegionFoam case. When i run the chtMultiRegionFoam solver I get an error i pasted below. I compiled the Debug OpenFoam version hoping for some more feedback about the possible errors, but the error report remained the same.
Is this the Debug error report i should get with Debug OpenFoam version? Any idea where to look for the error? Regards, Klemen Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0 Exec : chtMultiRegionFoam Date : Apr 04 2013 Time : 12:54:07 Host : "klemen-VirtualBox" PID : 7150 Case : /home/klemen/OpenFOAM/klemen-2.2.0/run/klemen/dewarCHT2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region nitrogen for time = 0 Create solid mesh for region tube for time = 0 *** Reading fluid mesh thermophysical properties for region nitrogen Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } #0 Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/printStack.C:221 #1 Foam::sigFpe::sigHandler(int) at ~/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/signals/sigFpe.C:117 #2 Uninterpreted: #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ~/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/rhoThermo/heRhoThermo.C:82 #4 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::heRhoThermo(Foam::fvMesh const&, Foam::word const&) at ~/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/rhoThermo/heRhoThermo.C:119 #5 Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ~/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/rhoThermo/rhoThermo.H:83 #6 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&, Foam::word const&) at ~/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/lnInclude/basicThermoTemplates.C:163 #7 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ~/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/rhoThermo/rhoThermo.C:146 #8 at ~/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/heatTransfer/chtMultiRegionFoam/./fluid/createFluidFields.H:31 #9 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #10 in "/home/klemen/OpenFOAM/OpenFOAM-2.2.0/platforms/linuxGccDPDebug/bin/chtMultiRegionFoam" Floating point exception (core dumped) |
April 4, 2013, 08:14 |
klemen
Rep Power: 13 |
Now i noticed one more thing. When i run the OpenFoam 2.2.0 default precompiled version installed at /opt/etc.. and test the "tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater" everything seems to work fine - if i open the log file i can see the solver is running. But if i ran the same example with the compiled Debug OpenFoam 2.2.0 version, i get an error listed below. Should install the ThirdParty software to run those examples?
-------------------------------------------------------------------------- Sorry! You were supposed to get help about: find-available:not-valid But I couldn't open the help file: /home/klemen/OpenFOAM/ThirdParty-2.2.0/platforms/linuxGcc/openmpi-1.6.3/share/openmpi/help-mca-base.txt: No such file or directory. Sorry! -------------------------------------------------------------------------- [klemen-VirtualBox:09274] *** Process received signal *** [klemen-VirtualBox:09274] Signal: Segmentation fault (11) [klemen-VirtualBox:09274] Signal code: Address not mapped (1) [klemen-VirtualBox:09274] Failing at address: 0x14 [klemen-VirtualBox:09274] [ 0] [0xdd140c] [klemen-VirtualBox:09274] [ 1] /usr/lib/libopen-pal.so.0(mca_base_select+0x135) [0xa8c9e5] [klemen-VirtualBox:09274] [ 2] /usr/lib/libopen-pal.so.0(opal_crs_base_select+0xae) [0xa9fc0e] [klemen-VirtualBox:09274] [ 3] /usr/lib/libopen-pal.so.0(opal_cr_init+0x415) [0xa7bfd5] [klemen-VirtualBox:09274] [ 4] /usr/lib/libopen-pal.so.0(opal_init+0x15b) [0xa7b77b] [klemen-VirtualBox:09274] [ 5] /usr/lib/libopen-rte.so.0(orte_init+0x4d) [0xd476cd] [klemen-VirtualBox:09274] [ 6] mpirun() [0x804a3c1] [klemen-VirtualBox:09274] [ 7] mpirun() [0x8049f4f] [klemen-VirtualBox:09274] [ 8] /lib/i386-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x3d54d3] [klemen-VirtualBox:09274] [ 9] mpirun() [0x8049ea1] [klemen-VirtualBox:09274] *** End of error message *** |
April 6, 2013, 08:00 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Klemen,
Let me answer to one post at a time :
Bruno
April 16, 2013, 05:46 |
klemen
Rep Power: 13 |
Thank you for the reply. I tested the debug version once again, and now i get some more feedback - i issume the nomber at the end of error message represents the code line number? I checked that line, but this did not help me much. Any idea what could be the problem with my simulation. The simulation runs for some time and then stops, reporting the errors below. I am testing a simple chtMultiRegionFoam example. I uploaded my configuration: http://www.speedyshare.com/SS28g/CHTtest.tar.gz
--- DEBUG MODE ---- #0 Foam::error:rintStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/printStack.C:221 #1 Foam::sigFpe::sigHandler(int) at ~/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/signals/sigFpe.C:117 #2 Uninterpreted: #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ~/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/matrices/lduMatrix/solvers/GAMG/GAMGSolverScale.C:56 #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ~/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/matrices/lduMatrix/solvers/GAMG/GAMGSolverSolve.C:297 #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ~/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/matrices/lduMatrix/solvers/GAMG/GAMGSolverSolve.C:99 #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ~/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/fvMatrices/fvScalarMatrix/fvScalarMatrix.C:164 #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ~/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvMatrixSolve.C:81 #8 at ~/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/heatTransfer/chtMultiRegionFoam/./fluid/pEqn.H:61 #9 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #10 in "/home/klemen/OpenFOAM/OpenFOAM-2.2.0/platforms/linuxGccDPDebug/bin/chtMultiRegionFoam" Floating point exception (core dumped) --- same, but NO DEBUG --- #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/chtMultiRegionFoam" #8 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/chtMultiRegionFoam" #9 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #10 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/chtMultiRegionFoam" Floating point exception (core dumped) Last edited by fogl; April 16, 2013 at 09:20. |
April 17, 2013, 16:27 |
#5 | |
Bruno Santos
Rep Power: 128 |
Hi Klemen,
Sometimes looking at where it crashed gives the information you need to know, but other times you have to go up into the previous function calls and look at how the variables are right before it crashes/crashed. I thought that in those links I posted, I had mentioned gdbOF... apparently I didn't, so here it is: http://openfoamwiki.net/index.php/Contrib_gdbOF - this can help you to use GDB to ascertain what the variables had at the time of the crash. Eclipse is another one that might help: http://openfoamwiki.net/index.php/Ho...M_with_Eclipse But other times, the solution is to step back and look at the formulation of your changes to the source code and case. So, a little explanation of what you're trying to do would make it easier to help you... In addition, the error messages you gave in the first post are rather different from these latest ones you've posted about... Best regards, Bruno
April 18, 2013, 07:02 |
klemen
Rep Power: 13 |
Thank you Bruno,
I am not making any changes to the source code (yet). I am just testing a simple case of cold nitrogen flow through a round tube. The error message I pasted above was different, i think that the solver did not even start. Then i did some changes to BC and now the solver start and than stops after some time. I thought that debugging the case will lead me to to the source of error - isn't this the way it should be done? BTW, I plotted the solution using paraFoam, but i could not find the cause of problem. Regards, Klemen |
April 18, 2013, 16:58 |
#7 | |
Bruno Santos
Rep Power: 128 |
Hi Klemen,
Debugging gets us closer to the reason of why it crashes, because OpenFOAM currently doesn't have a smart system that simply says: "your field XYZ has a non admissible value". OK, remember what I wrote about having to look further back into the past code? On line #8 of the stack list you have this: Quote:
If you look at this file, you'll see that it's pointing to the very last line of this snippet of source code: Code:
fvScalarMatrix p_rghEqn ( p_rghDDtEqn - fvm::laplacian(rhorAUf, p_rgh) ); p_rghEqn.solve ( mesh.solver ( p_rgh.select ( ( oCorr == nOuterCorr-1 && corr == nCorr-1 && nonOrth == nNonOrthCorr ) ) ) ); So, what happens is something like this:
fvScalarMatrix p_rghDDtEqn ( fvc::ddt(rho) + psi*correction(fvm::ddt(p_rgh)) + fvc::div(phiHbyA) ); My bet is on the "p_rgh" field... you probably have values that either not allowed... look into other tutorial cases, to figure out what you might be doing wrong Best regards, Bruno
Memory protection in OpenFOAM / combinig with FORTRAN | botp | OpenFOAM Programming & Development | 2 | February 15, 2016 12:25 |
[Gmsh] gmsh 2.6.0 conversion to OpenFoam 160 | rosswin | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2013 07:34 |
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x | wyldckat | OpenFOAM Bugs | 18 | October 21, 2010 05:51 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
The OpenFOAM extensions project | mbeaudoin | OpenFOAM | 16 | October 9, 2007 09:33 |
