omegaWallFunction implementation
Like Tree3Likes
  • 3 Post By fumiya
Old   April 9, 2013, 13:37
Default omegaWallFunction implementation
Florian
Horus is on a distinguished road
I'm studying the implementation of the incompressible omegaWallFunction.
http://foam.sourceforge.net/docs/cpp/a09165_source.html
00207         scalar omegaVis = 6.0*nuw[faceI]/(beta1_*sqr(y[faceI]));
00208
00209         scalar omegaLog = sqrt(k[faceCellI])/(Cmu25*kappa_*y[faceI]);
00210
00211         omega[faceCellI] = sqrt(sqr(omegaVis) + sqr(omegaLog));
\omega = \sqrt{\omega_{vis}^2 + \omega_{log}^2}
\omega_{vis} = \frac{6 \nu}{\beta_1 \cdot y^2}
\omega_{log} = \frac{k}{\sqrt[4]{C_\mu} \cdot \kappa \cdot y}
This clearly becomes oo when y approaches 0. Does this account for the turbulence damping near the wall?
Next question: What is G?
00173     volScalarField& G =
00174         const_cast<volScalarField&>
00175         (
00176             db().lookupObject<volScalarField>
00177             (
00178                 turbulence.type() + ".G"
00179             )
00180         );
And set here:
00213         G[faceCellI] =
00214             (nutw[faceI] + nuw[faceI])
00215            *magGradUw[faceI]
00216            *Cmu25*sqrt(k[faceCellI])
00217            /(kappa_*y[faceI]);
00218     }
The paper mentioned in the source code is available nowhere...
I'm especially clueless that the last part with the G is about?
Thanks!
Florian
Horus is offline   Reply With Quote
Old   April 9, 2013, 18:08
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
Hi Florian,
For the second question, the followings will be of help:
The term G is the production of turbulent kinetic energy.
Hope this helps,
Fumiya
Horus, kiddmax and bmikuz like this.
fumiya is offline   Reply With Quote
Old   April 28, 2014, 21:10
Daniel
dancfd is on a distinguished road
Hello all,
I noticed that the logarithmic component of omega1 in the code is not representative of the Menter 2001 paper.
The code is:
Which gives:
\omega_{log} = \frac{\sqrt{k}}{\sqrt[4]{C_\mu} \kappa y}
Menter 2001 gives:
\omega_{log} = \frac{u_\tau}{\sqrt[4]{C_\mu} \kappa y}
Where C_mu = 0.09.
Why the difference? A message above makes reference to the following website: http://www.cfd-online.com/Wiki/Two_e...bulence_models
The last term of the last equation in the "Standard Wall Functions" section at that link matches the code, but it is still not clear why the code chose the equation that was selected (Wilcox 1994 eq 6.84) and not that which was defined in Menter 2001.
Does anyone know why the code is what it is, and not in line with Menter 2001?
Thanks,
Daniel
dancfd is offline   Reply With Quote
Old   September 21, 2015, 05:54
Default Implementation of SST Wall Function (Menter)
Mubashir Ali
mooby is on a distinguished road
Send a message via Skype™ to mooby
I am also wondering why is there difference between Menter Wall function definition and OF wall function definition. do you have an answer now ??
mooby is offline   Reply With Quote
Old   September 23, 2015, 08:05
Blanco
Blanco is on a distinguished road
do you have the Menter 2001 paper? I'm not able to find it anywhere...but all my references and docs are citing the
\omega_{log} = \frac{\sqrt{k}}{\sqrt[4]{C_\mu} \cdot \kappa \cdot y}
which is what is implemented in OF (correctly IMHO).
Best regards,
Andrea
Blanco is offline   Reply With Quote
Old   September 23, 2015, 08:59
Default Menter 2001 Paper
Mubashir Ali
Hello Andrea,
Unfortunately I also dont hv Menter 2001 Paper. Nevertheless, I have requested someone on CFD online. He hopefully will share it with me. If I receive it, will surely share it with you
Old   September 23, 2015, 09:41
Blanco
Ok thanks,
because I'm wondering if dancfd was correctly citing Menter formula in his post... I mean, if instead of dancfd cited formula which is
we have
\omega_{log} = \frac{u_\tau}{\sqrt{C_\mu} \kappa y}
then everything is solved because we know that
\omega_{log} = \frac{u_\tau}{\sqrt{C_\mu} \kappa y} = \frac{\sqrt{k}}{\sqrt[4]{C_\mu} \cdot \kappa \cdot y}
Let's see if someone could provide Menter paper to check.
Best regards,
Andrea
Old   September 23, 2015, 21:08
Daniel
The COBEM paper is available in the public domain here:
http://www.abcm.org.br/anais/cobem/2001/home.htm -> just go to Lectures link
It was posted by someone else in this thread, #43:
http://www.cfd-online.com/Forums/ope...t-paper-3.html
It looks like you are correct, there must have been an error in my post above because sqrt(Cmu = 0.09) = 0.3 and then everything matches up (if it is Cmu^1/2 instead of ^1/4). Apologies for the confusion caused by this error.
Dan
Old   September 24, 2015, 01:59
Mubashir Ali
Hello Andrea,
Daniel "Dancfd" have sent me the Esh & Menter Paper. If you wish I can forward it to you or you can request Daniel for it
Old   September 24, 2015, 02:59
Blanco
Thanks a lot Daniel and Ali,
so everything is ok now, we can say OF is correct!
Best regards,
Andrea
Old   September 29, 2015, 08:52
Default Smoothing Function for Friction Velocity
  #11
Mubashir Ali
Hi Adrea/Daniel,
I was wondering the Omega_Log term is defined by Menter as
Omega_Log = U_tau/(0.3*kappa*y)
where U_tau is calculated from U_Vis = U1/y & U_Log = U1/((ln(y)/k)+c)
U_Tau = ( (u_Vis)^4 + (U_Log)^4)^(1/4)
But in OF omega_Log is approximated by I think Spalding assumption
i.e. U_Tau = cmu^(1/4)*sqrt(k)
So, what if Menter U_Tau is used in omegaWallFunction .. will that improve the results i.e. mesh independence
Free CFD code with implementation of Menter's k-omega SST model nikola_m Main CFD Forum 2 May 8, 2020 12:13
a little confused with the implementation of compressibleInterFoam su_junwei OpenFOAM Running, Solving & CFD 2 May 7, 2014 17:33
Implementation issues of fvSchemes / laplacianScheme, in particular gaussLaplacianSch thomek OpenFOAM Programming & Development 0 October 18, 2010 05:10
Request for help so as to debug MAC implementation HectorRedal Main CFD Forum 0 September 13, 2010 16:52
Please explain the implementation of species transport Eqn in reactingFoam kallipygian OpenFOAM Running, Solving & CFD 0 October 13, 2008 07:29
