error: no matching function for call to
Old   June 6, 2018, 01:32
Default error: no matching function for call to
krishna kant
kk415 is on a distinguished road
Hi
I am trying to make a dual grid icoFoam solver in which Navier-Stokes is solved in one grid and temperature is solved in another grid.
I am defining my two regions similar to the concept of chtmultiRegionFoam. Now the solver need an interpolation function between two grids.
The solver.c I am showing below:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration |
\\ / A nd | Copyright (C) 2011-2016 OpenFOAM Foundation
\\/ M anipulation |
License
This file is part of OpenFOAM.
OpenFOAM is free software: you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
You should have received a copy of the GNU General Public License
along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>.
Application
icoFoam
Description
Transient solver for incompressible, laminar flow of Newtonian fluids.
#include "fvCFD.H"
#include "regionProperties.H"
#include "pisoControl.H"
#include "meshToMesh0.H"
//#include "MapMeshes.H"
#include "IOobjectList.H"
#include "MapConsistentVolFields.H"
#include "UnMapped.H"
template<template<class> class CombineOp>
void MapConsistentMesh
const Foam::IOobjectList& objects,
const fvMesh& meshSource,
const fvMesh& meshTarget,
const meshToMesh0:rder& mapOrder
// Create the interpolation scheme
meshToMesh0 meshToMesh0Interp(meshSource, meshTarget);
// Map volFields
MapConsistentVolFields<scalar>
objects,
meshToMesh0Interp,
mapOrder,
CombineOp<scalar>()
MapConsistentVolFields<vector>
objects,
meshToMesh0Interp,
mapOrder,
CombineOp<vector>()
// Search for list of target objects for this time
// IOobjectList objects(meshTarget, meshTarget.time().timeName());
//objects.add(U);
//objects.add(p);
//objects.add(T);
// Mark surfaceFields as unmapped
UnMapped<surfaceScalarField>(objects);
UnMapped<surfaceVectorField>(objects);
UnMapped<surfaceSphericalTensorField>(objects);
UnMapped<surfaceSymmTensorField>(objects);
UnMapped<surfaceTensorField>(objects);
// Mark pointFields as unmapped
UnMapped<pointScalarField>(objects);
UnMapped<pointVectorField>(objects);
UnMapped<pointSphericalTensorField>(objects);
UnMapped<pointSymmTensorField>(objects);
UnMapped<pointTensorField>(objects);
//mapLagrangiannew(meshToMesh0Interp);
int main(int argc, char *argv[])
#define NO_CONTROL
#define CREATE_MESH createMeshesPostProcess.H
#include "postProcess.H"
#include "setRootCase.H"
#include "createTime.H"
#include "createMeshes.H"
#include "createFields.H"
#include "initContinuityErrs.H"
#include "createTimeControls.H"
#include "readSolidTimeControls.H"
#include "setInitialMultiRegionDeltaT.H"
meshToMesh0:rder mapOrder = meshToMesh0::INTERPOLATE;
Info<< "\nStarting time loop\n" << endl;
while (runTime.loop())
#include "readTimeControls.H"
#include "setMultiRegionDeltaT.H"
Info<< "Time = " << runTime.timeName() << nl << endl;
//#include "CourantNo.H" //?
forAll(fluidRegions, i)
Info<< "\nSolving for fluid region "
<< fluidRegions[i].name() << endl;
pisoControl piso(fluidRegions[i]);
#include "setRegionFluidFields.H"
// Momentum predictor
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
if (piso.momentumPredictor())
solve(UEqn == -fvc::grad(p));
// --- PISO loop
while (piso.correct())
volScalarField rAU(1.0/UEqn.A());
volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p));
surfaceScalarField phiHbyA
"phiHbyA",
fvc::flux(HbyA)
+ fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
adjustPhi(phiHbyA, U, p);
// Update the pressure BCs to ensure flux consistency
constrainPressure(p, U, phiHbyA, rAU);
// Non-orthogonal pressure corrector loop
while (piso.correctNonOrthogonal())
// Pressure corrector
fvScalarMatrix pEqn
fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve(fluidRegions[i].solver(p.select(piso.finalInnerIter())));
if (piso.finalNonOrthogonalIter())
phi = phiHbyA - pEqn.flux();
// #include "continuityErrs.H"
U = HbyA - rAU*fvc::grad(p);
U.correctBoundaryConditions();
//Interpolation from coarser to finer mesh
//MapConsistentMesh(fluidRegions[i], solidRegions[i], mapOrder);
meshToMesh0 meshToMesh0Interp(fluidRegions[i], solidRegions[i]);
Info<< nl
<< "Consistently creating and mapping fields for time "
<< fluidRegions[i].time().timeName() << nl << endl;
// Search for list of objects for this time
Foam::IOobjectList objects(fluidRegions[i], fluidRegions[i].time().timeName());
objects.add(U);
objects.add(p);
objects.add(T);
Info<< "object size" << objects.size()
<< endl;
MapConsistentMesh(objects, fluidRegions[i], solidRegions[i], mapOrder);
} //all fluid regions
//subtract= false;
forAll(solidRegions, i)
Info<< "\nSolving for solid region "
<< solidRegions[i].name() << endl;
#include "setRegionSolidFields.H"
//add these lines...
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T)
TEqn.solve();
//done adding lines...
//Interpolation from finer to coarser mesh
//MapConsistentMesh(solidRegions[i], fluidRegions[i], mapOrder);
} //all solid regions
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
I have highlighted the point where I am facing the problem. The error I am getting is error: no matching function for call to ‘MapConsistentMesh(Foam::IOobjectList&, Foam::fvMesh&, Foam::fvMesh&, Foam::meshToMesh0:rder&)’.
I am not getting what could be the reason for the error.
Can any one suggest something. It will be deeply appreciated.
Thanks
kk415 is offline   Reply With Quote
Old   June 6, 2018, 07:07
anonymous
simrego is on a distinguished road
Hi!
The reason for that is simply you don't have this function. At least not with these arguments.
I only found in doxygen this:
MapConsistentMesh (const fvMesh &meshSource, const fvMesh &meshTarget, const meshToMesh0:rder &mapOrder)
( https://cpp.openfoam.org/v5/MapMeshes_8H_source.html )
So there is no IOobjectList for the first argument. Only (mesh source, target, mapOrder).
simrego is offline   Reply With Quote
Old   June 7, 2018, 00:43
krishna kant
Originally Posted by simrego View Post
Hi!
Yes but I want to modify that function for my requirement and I defined this new function before the main function in the code shown before. So what is wrong in that definition
Old   June 7, 2018, 03:31
krishna kant
It is because the template line above the MapConsistentMesh function.
How does it works ? Any tutorials to understand that?
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Elements that limit the Courant number skabilan OpenFOAM Running, Solving & CFD 9 July 3, 2008 12:07
No matching function multiplying tensors for BC Erik OpenFOAM 3 March 20, 2008 13:05
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
