Which procedure to solve Ueqn without momentum predictor. |
July 2, 2013, 21:04 |
Dongyue Li
Rep Power: 17 |
This is icoFoam's code,: Code:
fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) ); solve(UEqn == -fvc::grad(p));//this term is only executed when the momentumPredictor flag is set to true // --- PISO loop for (int corr=0; corr<nCorr; corr++) { volScalarField rAU(1.0/UEqn.A()); volVectorField HbyA("HbyA", U); HbyA = rAU*UEqn.H(); surfaceScalarField phiHbyA ( "phiHbyA", (fvc::interpolate(HbyA) & mesh.Sf()) + fvc::ddtPhiCorr(rAU, U, phi) ); adjustPhi(phiHbyA, U, p); for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix pEqn ( fvm::laplacian(rAU, p) == fvc::div(phiHbyA) ); |
July 2, 2013, 23:37 |
Santiago Marquez Damian
Rep Power: 23 |
Hi, in the PISO method, U is predicted and then corrected in the pressure-velocity coupling loop, so that, if you don't predict the velocity, the velocity used to start the coupling loop is a derivative of the velocity in the last time step as is done in interFoam and other solvers.
In the code you've cited the matrix for the momentum equation is assembled so that you have the A and H methods available for the use in the PISO loop, the line: HbyA = rAU*UEqn.H(); calculates a first approximation for U using the H operator applied to the velocity of the last-timestep or which was predicted when you solved the UEqn (if you did it) and the A operator. If you need it, please check the definition of these operators in chapter 2.7 of my Ph.D. thesis The link to my PhD thesis is provided in my user page at openfoamwiki.net: http://openfoamwiki.net/index.php/User:Santiagomarquezd and Jasak's Ph.D. and other's thesis. Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar Last edited by wyldckat; May 24, 2016 at 17:39. Reason: rectified link according to request |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
Linearized NS euqations: how to solve them?(problem with Matrix operations..) | matteoL | OpenFOAM Running, Solving & CFD | 0 | November 18, 2009 06:58 |
OpenFOAM wonbt solve the momentum U equation | sek | OpenFOAM Running, Solving & CFD | 5 | March 6, 2008 16:27 |
AirPak 2.06 solve problem | ABS | FLUENT | 0 | October 4, 2005 17:58 |
How to solve another continuum and momentum eqn? | west_wing | FLUENT | 0 | August 25, 2003 10:00 |
