CHEMKIN new reaction type (reactingFoam)
Old   July 27, 2013, 15:53
Default CHEMKIN new reaction type (reactingFoam)
Chris L
vbchris is on a distinguished road
Hi all,
Simple problem. I am working to add a new reaction type to reactingFoam.
I am using the chemKin utility to add a new reaction. However, I'm not sure how to get chemKinReader to use my new reactionRate. I have modified the reactionRate and chemKinReader files to accept a new reactionRate type (or so I thought). But on run time it doesn't seem to like the syntax of the chemkin case file.
The attached file has the modified chemKinReader and reactionRate Files.
The reaction rate model is a solid core model.
Here's the error.
Selecting chemistryReader chemkinReader
--> FOAM FATAL ERROR:
unknown third-body specie SLDC on line 21
Valid species are :
7
CuO
N2
Cu
CO2
O2
CH4
H2O
    From function chemkinReader::lex()
    in file chemistryReaders/chemkinReader/chemkinLexer.L at line 1179.
FOAM exiting
Here is the case chemKin file (copper oxide rxn)
! GRI-Mech Version 3.0 7/30/99  CHEMKIN-II format
! See README30 file at anonymous FTP site unix.sri.com, directory gri;
! WorldWideWeb home page http://www.me.berkeley.edu/gri_mech/ or
! through http://www.gri.org , under 'Basic  Research',
! for additional information, contacts, and disclaimer
ELEMENTS
H  C  N  O CU
END
SPECIES
CH4     O2      H2O     CO2     N2     Cu      CuO
END
REACTIONS JOULES/MOLE
 CH4 + 4CuO = CO2 + 2H2O + 4Cu             4.5e-4  0.0  60
     FORD / CH4 0.4/
     FORD / CuO 4/
     SLDC / 1.0 0.00003958 1.5 0.4 0.0015 /
 4Cu + 2O2  = 4CuO                         4.7e-6  0.0  15
     FORD / Cu  2/
     FORD / O2  1/
END
Any comments are welcome.
Thanks,
Chris
vbchris is offline   Reply With Quote
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 08:07
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
