Heat transfer in a channel: solving for T; questions about Pe and solving
Old   July 11, 2013, 09:27
Default Heat transfer in a channel: solving for T; questions about Pe and solving
buffi is on a distinguished road
I'm doing CFD for a wavy channel, using simpleFoam and the k-omega-SST model to solve the velocity field. I'd now like to solve for T, and did some intermediate processing (post-U, pre-T):
For my first attempt at solving T (scalarTransportFoam) I used
div(phi,T) Gauss upwind;
which worked well and converged quickly. However, when switching to Gauss linear, the solution diverged. A colleague suggested to check the Peclet number first, which I calculated with the following code snippet:
    // characteristic length of each cell: cbrt(V)
    volScalarField CLen
      IOobject (
        "CLen",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
      mesh,
      dimensionedScalar(
        "CLen",
        dimLength,
        0.
    forAll (CLen, i)
      CLen.internalField()[i] = Foam::cbrt(mesh.V()[i]);
    // Pe number
    volScalarField Pe
      IOobject (
        "Pe",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
      mesh,
      dimensionedScalar(
        "Pe",
        dimless,
        0.
    Pe = CLen*mag(U)/(alpha + turbulence->nut()/Prt);
The results are somewhere between 6e-5 and 300. The books say that I'd need Pe < 2 for more accurate schemes.
My main question now is: what can I do to get a usable temperature field? While Pe > 2 does not necessarily mean that the solution will be wrong, I could increase alpha and nu (in order to maintain Pr = 7), but that would mean that I have to increase U or the domain size as well to adjust Re. Wouldn't that just lead to the same problem, but on a different scale?
Another possibility is of course that my code for Pe is just plain wrong. Maybe someone could comment on this; OF's Pe tool just calculates Pe at the boundary, using a different equation.
I can not refine the mesh by a factor of 150, as I already have about 2 million cells.
Regards
buffi is offline   Reply With Quote
Old   July 22, 2013, 06:01
Artem Shaklein
ARTem is on a distinguished road
Hello, buffi.
Try to use "limitedLinear 1" for convective fluxes. It will use linear and switch to upwind in areas with big variable value gradients.
ARTem is offline   Reply With Quote
