Problem in fvMesh.C when using topological changes. OpenFoam 2-2-x
Old   August 14, 2013, 11:57
Default Problem in fvMesh.C when using topological changes. OpenFoam 2-2-x
Horacio Aguerre is on a distinguished road
Hi All,
I have the following problem when I run cases with topological changes on the mesh (I have implemented a layering strategy which uses the layerAdditionRemoval class).
OpenFoam Version: 2.2.0
File: fvMesh.C
Method: mapFields(const mapPolyMesh& meshMap)
When mapping the old cells volume ,(just mapping to new cell labels), (fvMesh.C:562)
if (V0Ptr_)
        scalarField& V0 = *V0Ptr_;
        scalarField savedV0(V0);
        V0.setSize(nCells());
        forAll(V0, i)
            if (cellMap[i] > -1)
                V0[i] = savedV0[cellMap[i]];
            else
                V0[i] = 0.0;
Here it is waited that V0PTr_ to be the old time level pointer to cells volume. However V0Ptr_ is mapped previously by, (fvMesh.C:550)
MapDimensionedFields<scalar, fvMeshMapper, volMesh>(mapper);
and then the V0PTr_, which is assigned to savedV0, looses its relation with cellMap and the mapping
results uncorrect. (When cells are removed due to topological changes on the mesh, the program crashes due to try to access to a wrong memory position because now cellMap[i] is bigger than list savedV0 size).
I have seen that in the previous OpenFOAM version 2.0-x, the MapDimensionedFields was not use in fvMesh.C. But, after OpenFoam version 2.1-x the MapDimensionedFields were added.
The cases run without problems when i comment either the line (fvMesh.C:550) or the group after (fvMesh.C:562).
Is the "mapping", that is done from (fvMesh.C:562), no more necessary when the MapDimensionedFields is used before?
Thanks, Horacio.
Horacio Aguerre is offline   Reply With Quote
To solve combustion problem in openFoam yash.aesi OpenFOAM 0 July 10, 2013 07:35
compiler problem with OpenFOAM installation belkadi OpenFOAM Installation 4 May 22, 2013 10:26
[OpenFOAM] Color display problem to view OpenFOAM results. Sargam05 ParaView 16 May 11, 2013 00:10
Problem with mpirun with OpenFOAM jiejie OpenFOAM 3 July 7, 2010 19:30
OpenFOAM 1.6 CreatePatch Problem TarifaPirata OpenFOAM Bugs 1 September 10, 2009 04:35
