September 13, 2013, 09:14 |
setfields for alpha
belkadi
Rep Power: 12 |
Dear Foamers,
I've created a geometry to simulate air injection into a tank filled with water as shown in the attached file. I've also used the setFields to define the alpha in the system. alpha =1 for the water inside the tank. alpha =0 for the air in the injector (by suing the celltobox). I have some problems with this. I could not define these alpha in my mesh. I think that I've missed something, after processing all the geometry is with alpha = 1 although using the celltobox with alpha = 0 ! Please could anyone help me ? Thanks in advance ! Kind regards // blockMesh : Block mesh description file // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; // ************************************ } convertToMeters 1; //5 mm column diameter //10 cm length //Width of middle square section //how many cells in the square section //how many cells from square section to perimeter // how many cells from top to bottom vertices ( // partie cylindre sup ( 1.25 0.0 1.25) // Vertex fiveoclocksqb = 0 (-1.25 0.0 1.25) // Vertex sevenoclocksqb = 1 (-1.25 0.0 -1.25) // Vertex elevenoclocksqb = 2 ( 1.25 0.0 -1.25) // Vertex oneoclocksqb = 3 ( 1.76776695455285 0.0 1.76776695137989) // Vertex fiveoclockcb = 4 (-1.76776695455285 0.0 1.76776695137989) // Vertex sevenoclockcb = 5 (-1.76776695455285 0.0 -1.76776695137989) // Vertex elevenoclockcb = 6 ( 1.76776695455285 0.0 -1.76776695137989) // Vertex oneoclockcb = 7 ( 1.25 4 1.25) // Vertex fiveoclocksqt = 8 (-1.25 4 1.25) // Vertex sevenoclocksqt = 9 (-1.25 4 -1.25) // Vertex elevenoclocksqt = 10 ( 1.25 4 -1.25) // Vertex oneoclocksqt = 11 ( 1.76776695455285 4 1.76776695137989) // Vertex fiveoclockct = 12 (-1.76776695455285 4 1.76776695137989) // Vertex sevenoclockct = 13 (-1.76776695455285 4 -1.76776695137989) // Vertex elevenoclockct = 14 ( 1.76776695455285 4 -1.76776695137989) // Vertex oneoclockct = 15 // partie injecteur (-1.25 -2 0.11) // Vertex sevenoclockct = 16 (-1.75 -2 0.11) // Vertex elevenoclockct = 17 (-1.75 -2 -0.11) // Vertex sevenoclockct = 18 (-1.25 -2 -0.11) // Vertex elevenoclockct = 19 (-1.25 -2.22 0.11) // Vertex sevenoclockct = 20 (-1.75 -2.22 0.11) // Vertex elevenoclockct = 21 (-1.75 -2.22 -0.11) // Vertex sevenoclockct = 22 (-1.25 -2.22 -0.11) // Vertex elevenoclockct = 23 // partie cone ( 0.625 -2 0.625) // Vertex fiveoclocksqb = 24 (-0.625 -2 0.625) // Vertex sevenoclocksqb = 25 (-0.625 -2 -0.625) // Vertex elevenoclocksqb = 26 ( 0.625 -2 -0.625) // Vertex oneoclocksqb = 27 ( 0.88 -2 0.88) // Vertex fiveoclockcb = 28 (-0.88 -2 0.88) // Vertex sevenoclockcb = 29 (-0.88 -2 -0.88) // Vertex elevenoclockcb = 30 ( 0.88 -2 -0.88) // Vertex oneoclockcb = 31 // partie cone bas (après injecteur) 1 ( 0.625 -2.4 0.625) // Vertex fiveoclocksqb = 32 (-0.625 -2.4 0.625) // Vertex sevenoclocksqb = 33 (-0.625 -2.4 -0.625) // Vertex elevenoclocksqb = 34 ( 0.625 -2.4 -0.625) // Vertex oneoclocksqb = 35 ( 0.88 -2.4 0.88) // Vertex fiveoclockcb = 36 (-0.88 -2.4 0.88) // Vertex sevenoclockcb = 37 (-0.88 -2.4 -0.88) // Vertex elevenoclockcb = 38 ( 0.88 -2.4 -0.88) // Vertex oneoclockcb = 39 // partie cone bas (après injecteur) 2 ( 0.625 -2.22 0.625) // Vertex fiveoclocksqb = 40 (-0.625 -2.22 0.625) // Vertex sevenoclocksqb = 41 (-0.625 -2.22 -0.625) // Vertex elevenoclocksqb = 42 ( 0.625 -2.22 -0.625) // Vertex oneoclocksqb = 43 ( 0.88 -2.22 0.88) // Vertex fiveoclockcb = 44 (-0.88 -2.22 0.88) // Vertex sevenoclockcb = 45 (-0.88 -2.22 -0.88) // Vertex elevenoclockcb = 46 ( 0.88 -2.22 -0.88) // Vertex oneoclockcb = 47 ); blocks ( //square block hex ( 1 0 3 2 9 8 11 10 ) (10 10 5) simpleGrading (1 1 1) //slice1 hex ( 5 4 0 1 13 12 8 9 ) (10 10 5) simpleGrading (1 1 1) //slice2 hex ( 1 2 6 5 9 10 14 13 ) (10 10 5) simpleGrading (1 1 1) //slice3 hex ( 2 3 7 6 10 11 15 14 ) (10 10 5) simpleGrading (1 1 1) //slice4 hex ( 3 0 4 7 11 8 12 15 ) (10 10 5) simpleGrading (1 1 1) // cone //square block hex ( 25 24 27 26 1 0 3 2 ) (10 10 5) simpleGrading (1 1 1) //slice1 bis hex ( 29 28 24 25 5 4 0 1 ) (10 10 5) simpleGrading (1 1 1) //slice2 bis hex ( 25 26 30 29 1 2 6 5 ) (10 10 5) simpleGrading (1 1 1) //slice3bis hex ( 26 27 31 30 2 3 7 6 ) (10 10 5) simpleGrading (1 1 1) //slice4bis hex ( 27 24 28 31 3 0 4 7 ) (10 10 5) simpleGrading (1 1 1) // cone bas (après injecteur) //square block hex ( 33 32 35 34 41 40 43 42 ) (10 10 5) simpleGrading (1 1 1) //slice1 hex ( 37 36 32 33 45 44 40 41 ) (10 10 5) simpleGrading (1 1 1) //slice2 hex ( 33 34 38 37 41 42 46 45 ) (10 10 5) simpleGrading (1 1 1) //slice3 hex ( 34 35 39 38 42 43 47 46 ) (10 10 5) simpleGrading (1 1 1) //slice4 hex ( 35 32 36 39 43 40 44 47 ) (10 10 5) simpleGrading (1 1 1) // cone bas 2 (après injecteur) //square block hex ( 41 40 43 42 25 24 27 26 ) (10 10 5) simpleGrading (1 1 1) //slice1 hex ( 45 44 40 41 29 28 24 25 ) (10 10 5) simpleGrading (1 1 1) //slice2 hex ( 41 42 46 45 25 26 30 29 ) (10 10 5) simpleGrading (1 1 1) //slice3 hex ( 42 43 47 46 26 27 31 30 ) (10 10 5) simpleGrading (1 1 1) //slice4 hex ( 43 40 44 47 27 24 28 31 ) (10 10 5) simpleGrading (1 1 1) //injecteur hex ( 21 20 16 17 22 23 19 18 ) (10 10 10) simpleGrading (1 1 1) ); //create the quarter circles edges ( // pour cylindre arc 4 5 (0.0 0.0 2.5) arc 5 6 (-2.5 0.0 0.0) arc 6 7 (0.0 0.0 -2.5) arc 7 4 (2.5 0.0 0.0) arc 12 13 (0.0 4 2.5) arc 13 14 (-2.5 4 0.0) arc 14 15 (0.0 4 -2.5) arc 15 12 (2.5 4 0.0) // pour cone arc 28 29 (0 -2 1.25) arc 29 30 (-1.25 -2 0) arc 30 31 (0 -2 -1.25) arc 31 28 (1.25 -2 0) // pour cone bas 1 après injecteur arc 36 37 (0 -2.4 1.25) arc 37 38 (-1.25 -2.4 0) arc 38 39 (0 -2.4 -1.25) arc 39 36 (1.25 -2.4 0) // pour cone bas 2 après injecteur arc 44 45 (0 -2.22 1.25) arc 45 46 (-1.25 -2.22 0) arc 46 47 (0 -2.22 -1.25) arc 47 44 (1.25 -2.22 0) /* // pour injecteur arc 16 19 (-2.5 0.40 0) arc 16 20 (-2.5 0.56 0.16) arc 20 23 (-2.5 0.72 0) arc 23 19 (-2.5 0.56 -0.16) arc 17 18 (-3 0.40 0) arc 17 21 (-3 0.56 0.16) arc 21 22 (-3 0.72 0) arc 22 18 (-3 0.56 -0.16) */ ); boundary ( inlet { type wall; faces ( (21 17 18 22) ); } leftWall { type wall; faces ( (37 45 46 38) (45 29 30 46) (5 13 14 6 ) ); } rightWall { type wall; faces ( (36 28 31 39) (28 4 7 31) (4 12 15 7) ); } upperWall { type wall; faces ( (13 14 15 12) ); } lowerWall { type wall; faces ( (37 38 39 36) ); } frontAndBack { type empty; faces ( (17 21 20 16) (18 22 23 19) (37 45 44 36) (38 46 47 39) (45 29 28 44) (46 30 31 47) (29 5 4 28) (30 6 7 31) (5 13 12 4) (6 14 15 7) ); } ); patches ( ); for the setFields file : /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha1 1 //volScalarFieldValue U (0 0 0) ); regions ( boxToCell { box (-1.75 -2.22 0.11) (-1.25 -2 -0.11); fieldValues ( volScalarFieldValue alpha1 0 ); } ); // ************************************************** *********************** // Thanks ! Krimo |
September 13, 2013, 09:27 |
If you attach archive of you case it'll be easier to figure out what is wrong. Also if you'd like to insert blockMeshDict and setFieldsDict in the post, please, use [CODE] tags.
September 13, 2013, 09:56 |
Bernhard
Rep Power: 21 |
You set the default value to 1 and, after that, alpha to 0 inside the box in setFieldsDict. If you want to invert it, invert these values in the dictionary.
September 16, 2013, 05:39 |
belkadi
Rep Power: 12 |
Thanks for your reply Bernhardt, I tried your solutuion but it doesn't work.
In attached file the code source. Please if you have time you can check this problem. Thanks in advance ! Kind regards Krimo |
September 16, 2013, 05:47 |
In setFieldsDict you need to change this
box (-1.75 -2.22 0.11) (-1.25 -2 -0.11); Code:
box (-1.75 -2.22 -0.11) (-1.25 -2 0.11); |
September 16, 2013, 05:58 |
belkadi
Rep Power: 12 |
DearAlexeym,
Excellent, now it works ! it's magic Thank you very much for your help. I spent 3hours looking for this problem ! Again thank you very much Kind regards Krimo |
September 22, 2013, 20:59 |
Dongyue Li
Rep Power: 17 |
May I know why dont you use ICEM or the others but blockMesh? blockMesh is not convenient dealing with this.
November 25, 2014, 11:53 |
setFields
minoominaii
Rep Power: 11 |
i want to design a nuzzle with cylinder ,what should i replace in setfieldsDict
(region)?sphereToCell or boxToCell? |
how to use setFields in multiregionsolver | lg88 | OpenFOAM | 18 | June 12, 2022 18:57 |
InterFoam - setFields for a non-rectangular 3D domain | Ak_cfd | OpenFOAM Running, Solving & CFD | 24 | July 25, 2020 21:16 |
setFields not working | dsanza | OpenFOAM | 4 | October 18, 2018 09:43 |
Problems with the execution of the setFields utility. | foamer | OpenFOAM Pre-Processing | 5 | June 3, 2013 12:24 |
setFields tool does not assign water volume for given mesh. | paka | OpenFOAM | 2 | June 7, 2012 09:17 |
