Compilation error when trying to interpolate a dimensionedScalar&
Old   October 2, 2013, 04:52
Default Compilation error when trying to interpolate a dimensionedScalar&
Thomas Vossel
ThomasV is on a distinguished road
Hi!
I ran into another problem and don't know what I did wrong when writing my solver...
I want to do a fvc::interpolate() command on a dimensionedScalar. The scalar is created similar to the twoPhaseEulerFoam solver:
    const dimensionedScalar& rhoa = phasea->rho();
The interpolation command looks like this:
    surfaceScalarField rhoaf = fvc::interpolate(rhoa);
I now get the following error when compiling though:
pEqn.H:30:53: Fehler: keine passende Funktion für Aufruf von »interpolate(const Foam::dimensionedScalar&)«
That is the compiler is unable to get a function which fits to the interpolate call of the dimensionedScalar&. I don't know at which point I did something wrong as even in the twoPhaseEulerFoam code rhoa is used within an interpolate command...
ThomasV is offline   Reply With Quote
Old   October 2, 2013, 07:49
Thomas Vossel
I think I got closer to the solution. I guess it's not possible to interpolate a dimensionedScalar as its meant for volScalarFields only. As rhoa never shows up alone in an interpolation command of the twoPhaseEulerFoam solver I guess it cancels itself with some other components thus forming a valid interpolate statement...
I also found this definition of rhoa in one of the papers I'm reading:
Maybe it can work this way but unfortunately this seems to have problems in terms of the scope making its usage invalid. I'll see if I can figure out a way around that problem...
Old   October 5, 2013, 07:07
Retired Super Moderator
Bruno Santos
Greetings Thomas,
I didn't manage to properly read your questions, but I read that you mentioned "fvc::interpolate", so perhaps this little example of mine can help: https://github.com/wyldckat/reconstr...rpolate-fields
Best regards,
Bruno
Compilation error for OpenFOAM-ext on Ubantu 10.04 32 bit Sargam05 OpenFOAM Installation 13 March 22, 2014 05:21
Compilation error with OF 2.1.x GerhardHolzinger OpenFOAM Installation 5 September 18, 2012 09:04
Compilation Error (V 1.7.1; Icc 12.1.0, OpenMPI 1.4.3) floydfan OpenFOAM Installation 7 December 20, 2011 05:56
Interpolate in some points ivan_cozza OpenFOAM Post-Processing 2 April 22, 2009 08:58
Compilation Error.... Arnab Siemens 4 September 12, 2004 15:54
