October 9, 2013, 11:12 |
How to use List< List<vector> >
Canakkale Dardanelspor
Rep Power: 13 |
== 1 == I defined the following list of the list of vectors. Code:
List< List<vector> > example(...); I populate this with a number of lists of vectors. e.g. list1, list2, list3 ... etc. == 3 == The question is that how I can reach one of the vectors inside example? For example, I can reach the 3rd vector inside a "List<vector> other_example" like that: Code:
Info << other_example[2] << endl; == 4 == In the end, I would like to use this example list of lists in for loops so that I can do some algeabraic operation with them. Many thanks for any help in advance. |
October 10, 2013, 04:33 |
Jan
Rep Power: 19 |
have you tried
anotherExample[2][0] |
October 10, 2013, 05:01 |
Jan
Rep Power: 19 |
vector exampleVector = vector::zero; Info << "vector:" << tab << exampleVector << endl; scalar listLength(5); List<vector> exampleVectorList(listLength,vector::zero); forAll(exampleVectorList, i) { vector& v = exampleVectorList[i]; v = vector(i,2*i,3*i); Info << "vector:" << tab << v << endl; } Info << endl << endl; List<List<vector> > exampleVectorListList(listLength,exampleVectorList); forAll(exampleVectorListList,i) { List<vector>& vList = exampleVectorListList[i]; forAll(vList,j) { vector& v = vList[j]; Info << "vector:" << tab << v << endl; } } |
October 10, 2013, 05:28 |
Rep Power: 13 |
Many thanks for this reply.
I had tried example[2][0] at the first hand; but, it seems I misunderstood the error message. Now, it confirmed that I made some other mistake. Many thanks. |
1.7.x -> buoyantPimpleFoam -> hRhoThermo -> incompressible and icoPoly3ThermoPhysics? | will.logie | OpenFOAM Programming & Development | 1 | February 16, 2011 20:52 |
1.7.x -> buoyantPimpleFoam -> hRhoThermo -> incompressible and icoPoly3ThermoPhysics? | will.logie | OpenFOAM | 0 | December 16, 2010 07:08 |
CAD -> gMsh -> enGrid -> OpenFOAM Problem | AlGates | OpenFOAM | 7 | August 6, 2010 12:46 |
[Netgen] Geometry > Netgen > OpenFOAM | ericnutsch | OpenFOAM Meshing & Mesh Conversion | 9 | February 22, 2010 07:39 |
convection......-> conduction......-> convection | madasu | FLUENT | 3 | November 24, 2002 01:15 |
