method surfaceSum(...) of class fvc
Old   December 4, 2013, 07:42
Default method surfaceSum(...) of class fvc
maybee is on a distinguished road
hi,
I' m having problems with understanding the method surfaceSum(...) below:
template<class Type>
  192 tmp<GeometricField<Type, fvPatchField, volMesh> > surfaceSum
  193 (
  194     const tmp<GeometricField<Type, fvsPatchField, surfaceMesh> >& tssf
  195 )
  196 {
  197     tmp<GeometricField<Type, fvPatchField, volMesh> > tvf = surfaceSum(tssf());  //QUESTION
  198     tssf.clear();
  199     return tvf;
  200 }
with the overloaded operator () called on tssf in line 197:
template<class T>
213*inline const T& Foam::tmp<T>::operator()() const
214*{
215* if (isTmp_)   // bool isTmp_;  //- Flag for whether object is a temporary or a constant object
216* {
217* if (!ptr_)   //mutable T* ptr_;  //- Pointer to temporary object
218* {
219* FatalErrorIn("const T& Foam::tmp<T>::operator()() const")
220* << "temporary deallocated"
221* << abort(FatalError);
222* }
223*
224* return *ptr_;
225* }
226* else
227* {
228* return ref_;   //const T& ref_  //- Const reference to constant object
229* }
230*}
Question (line 197 marked in code snippet 1) :
In method surfaceSum(...) the input parameter tssf is passed to "another" surfaceSum(...) method. Wouldn t that cause some kind of endless loop, because in the new called method surfaceSum(...) the method gets called again and so on?
maybee is offline   Reply With Quote
Old   December 4, 2013, 08:22
akidess's Avatar
Anton Kidess
The ()-operator strips the object from it's tmp-"shell", so the following call to surfaceSum leads to a different method, namely one that is called when a GeometricField is passed: http://foam.sourceforge.net/docs/cpp...ce.html#l00138
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   December 4, 2013, 08:50
hi again,
The ()-operator strips the object from it's tmp-"shell",...
What do you mean by this? How is tmp stripped from the object tssf?
All I can see in the method operator () is that in line 215 it is proved if the object is tmp (temporary) and in line 217 if the pointer ptr_ is not NULL. If both these conditions are fullfilled the pointer ptr_ is dereferenced and returned in line 224.
Old   December 5, 2013, 03:35
akidess's Avatar
Anton Kidess
224* return *ptr_;
* What does this line do?
It dereferences the pointer stored in the tmp<> object, and returns the dereferenced pointer.
* What happens if you dereference a pointer pointing to an object?
You get access to that object. Note that in our case, the object in question is a vol*Field.
Does that make things clear?
Recommended reading: http://openfoamwiki.net/index.php/OpenFOAM_guide/tmp
Old   December 5, 2013, 04:12
224* return *ptr_;
1. I know about dereferencing a pointer , but if the pointer ptr_ points to an object of class tmp and gets dereferenced how should this strip the tmp from the object?
2. Furthermore, how do you know it is a vol*Field?
I have the following source code:
scalarField sumPhi
fvc::surfaceSum(mag(phi))().internalField()
with
const surfaceScalarField& phi
and therefore
→ template<class Type, template<class> class PatchField, class GeoMesh>
323*tmp<GeometricField<scalar, PatchField, GeoMesh> > mag
324*(
325* const GeometricField<Type, PatchField, GeoMesh>& gf
326*)
327*{
328* tmp<GeometricField<scalar, PatchField, GeoMesh> > tMag
329* (
330* new GeometricField<scalar, PatchField, GeoMesh>
331* (
332* IOobject
333* (
334* "mag(" + gf.name() + ')',
335* gf.instance(),
336* gf.db(),
337* IOobject::NO_READ,
338* IOobject::NO_WRITE
339* ),
340* gf.mesh(),
341* gf.dimensions()
342* )
343* );
344*
345* mag(tMag(), gf);
346*
347* return tMag;
348*}
and since the overloaded operator () [see my first post] is called on the result of method mag which returns a "tmp<GeometricField<scalar, PatchField, GeoMesh> > tMag" the pointer ptr_ should point at a "tmp<scalar> field".
Old   December 5, 2013, 04:21
akidess's Avatar
Anton Kidess
I figured you would after getting this far, but the next guy with the same question may not
tmp<GeometricField<scalar, PatchField, GeoMesh> > tMag stores a pointer to a GeometricField<scalar, PatchField, GeoMesh>, which is the same thing as a volScalarField. So when you call tMag() you will end up with the underlying volScalarField.
- Anton
Old   December 5, 2013, 04:36
, now I got it. Just one more question:
How did you know that ptr_ points to the geometricfield and not to the tmp<"geometricfield">?
Old   December 5, 2013, 05:34
akidess's Avatar
Anton Kidess
On line 330 of the code you posted a new object of GeometricField<> is allocated and it's pointer is passed on to the constructor of tmp<>: http://foam.sourceforge.net/docs/cpp...bf3c32f4c76004
Old   December 5, 2013, 05:42
Ok, thx alot. Question solved.
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM keepfit OpenFOAM 4 January 31, 2014 14:32
init() method of class UpStream maybee OpenFOAM Programming & Development 0 November 26, 2013 16:19
Help about the preconditioner in gmres method Dan Gao Main CFD Forum 3 July 5, 2008 01:18
About flowfield-dependent variation(FDV) method? Jinwon Main CFD Forum 1 December 4, 2007 21:13
tidal flow simulation using finite volume method Jason Qiu Main CFD Forum 0 October 20, 2002 02:34
