3D vector in OpenFOAM
Like Tree3Likes
  • 1 Post By ngj
  • 1 Post By ngj
  • 1 Post By wyldckat
Old   December 8, 2013, 09:20
Default 3D vector in OpenFOAM
Daniel73 is on a distinguished road
I would like to put some value in a simple 3d vector.
Do you know why this fragment of code does not work?(No matching function Error...)
vector someVec;
for (int i = 1; i < 11; ++i) someVec(i, 1, 1) = 0;
Also do you know why i cannot #include some c++ standard library such as std::vector in openFoam? (by typing #include <vector> , i get some errors,,this is happened also when i want to include some other c++ std libraries like map...
Daniel73 is offline   Reply With Quote
Old   December 8, 2013, 09:55
Bernhard
Bernhard is on a distinguished road
You would need
 vector someVec(i,1,1);
to properly initialize in C++. As you write it, you are calling some function with the name someVec, which does not exist clearly (as your errormessage states).
Bernhard is offline   Reply With Quote
Old   December 8, 2013, 10:06
Originally Posted by Bernhard View Post
You would need
I had initialized it before but it did not have any influence and again i got this error:
error: no match for call to ‘(Foam::vector {aka Foam::Vector<double>}) (int&, int, int)’
Old   December 8, 2013, 12:27
I need to define a 3D vector in OpenFOAM.
First,i tried to use std c++ vector library but #include <vector> gave me errors.
Second, i tried to use the foam vector,but It seems that the FOAM::vector does not act like as the std vector.For example in this fragment of code:
vector someVec(2,5,1);
Info << someVec.x() << " " << someVec.y() << endl ;
2 and 5 does not represent the index of the vector, but the value of the vector! (the output is : 2 5 )
If i use : vectorList vec; i get the error that vectorList did not declared in this scope.(i included the vectorList.H...)
Also including some other standard c++ library ,specially containers, gives me some errors.Is it correct way to use just : #include <aStdLibrary> ? (it works for iostream or cmath but not for containers)
Old   December 8, 2013, 16:40
Originally Posted by deepsterblue View Post
There's nothing stopping you from using STL vectors - that's why namespaces were invented in the first place.
The vector class in OpenFOAM is defined in the 'Foam' namespace, so it's actually a Foam::vector class. To use the STL version, simply use std::vector, or even plain ::vector.
I would like to use a std c++ vector library by the command e.g std::vector<int> vec;
But I've got error that ‘vector’ is not a member of ‘std’.
Do you know how can i use the standard library of c++ in OpenFOAM?
Old   December 8, 2013, 21:22
Sandeep Menon
deepsterblue will become famous soon enough
Here's the magic words:
#include <vector>
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   December 9, 2013, 04:56
#include <vector>
I forgot to say that i included that, but no influence!
maybe because there exist the vector.h header of the openFoam in InInclude folder and this code does not include the std library...
Old   December 9, 2013, 16:42
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Daniel,
I am not used to program using std, but if you want a list of 3d vectors, you can do as follows:
vectorField v(mySize);
Also, if you want an array of lists of vector, you can do as follows:
List<vectorField> listv(anotherSize);
Obviously, looping over listv and assigning a size to the vectorField is required.
Kind regards,
Niels
Daniel73 likes this.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   December 10, 2013, 01:56
Bernhard
This is your third topic about this issue. What is it that you are exactly trying to achieve? Are you sure you need std::vector? There is likely a better solution in the OpenFOAM framework.
Thus, isn't this a XY problem? ( http://mywiki.wooledge.org/XyProblem )
Old   December 10, 2013, 06:11
Let me clear the problem.
I want to use std::vector in OpenFOAM but nobody knows why it is not working.Somebody in a forum as an answer of the question of another person told that use std::vector.But for me it does not work even by including(vector.h).
Therefore i asked him again but he did not know,so i asked it generally maybe somebody can help me with an alternative way which does similar for me.
Old   December 10, 2013, 07:01
ngj
Hi Danial,
What is it you want to accomplish, which requires the use of std::vector?
Kind regards,
Niels
Old   December 10, 2013, 07:06
Originally Posted by ngj View Post
Hi Danial,
Kind regards,
Niels
I would like to save some coordinates in a vector, and be able to assign some value to this coordinates.
in std::vector i can use this way : vec(i,j,z)= some value ;
Now, as you told, im trying to use the List of vectors to save those coordinates but im thinking how to access each element of the list(a set of coordinate) to assign some value to that.
Old   December 10, 2013, 07:25
ngj
The class
pointField
is specifically designed to handle 3D coordinates. This would be a straight forward variable type to use. Also, using pointField aids in the reading of the code.
Kind regards
Niels
Old   December 10, 2013, 12:44
The class
pointField
Kind regards
Niels
Thank you very much.
I've done it.
Just a question, is it possible to visualize that pointFields in paraview ?
Old   December 10, 2013, 16:49
Retired Super Moderator
Bruno Santos
Greetings to all!
Clean up complete. Daniel73's related posts and respective answers have been merged into this thread, from the other two threads, namely:
This is a suitable question for the OpenFOAM Paraview & paraFoam... but anyway, the quick answer is: use the "Glyph" filter and use the "sphere" as the glyph.
Best regards,
Bruno
Old   December 12, 2013, 14:32
ngj
Thanks Bruno, I did not know how to visualise the point until know.
Cheers,
Niels
Old   January 21, 2014, 10:09
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Dear wyldcat,
Thank you for your answer but i need to plot my pointField which was initialized in my code.this just has x and y value in that and i need to plot those coordinates in paraview.
I dont have any volVoctorField to have my coordinates on that to use glyph.(my coordinates don't match exactly on the cell's coordinates)
Old   January 21, 2014, 15:28
Bruno Santos
Hi Daniel73,
Mmm... OK, if you can put the list of points and respective data into a CSV file, then you can:
  1. Open the CSV file in ParaView.
  2. Apply the filter "Table to Points".
  3. Then apply the filter "Plot Data".
    • In the display tab/section you can configure the data being plotted.
If you need more specific help, I'll need a more specific output example that needs to be plotted.
Best regards,
Bruno
Issues with OpenFoam sanjibdsharma OpenFOAM 0 August 14, 2009 08:41
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
2009 OpenFOAM Summer School in Zagreb, Croatia hjasak OpenFOAM Announcements from Other Sources 0 March 27, 2009 12:08
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 07:14
